1.9 TDI AWX sporadisches Zucken im Leerlauf / Motor geht aus | Posts 16+
Go to page: Previous  1, 2
crapSen
2005 Skoda Superb
dieselschrauber likes this.
Post10-08-2025, 11:20    Subject: Quote
Here are the pictures; from the inside, the relays didn't appear obviously damaged. What I, as a non-expert, observed is that there were discolorations on the contact surfaces of the switches within the relays. I don't know if this is still within the normal range; you can probably assess that better icon_wink.gif.
We are now talking about 475,000 km that the relays have traveled while performing their function. icon_razz.gif
 Blaues Relais
 File size:  1.5 MB
 Viewed:  848 times
 Blaues Relais
 File size:  1.74 MB
 Viewed:  777 times
 Blaues Relais
 File size:  1.97 MB
 Viewed:  772 times
 Blaues Relais
 File size:  1.77 MB
 Viewed:  767 times
 Blaues Relais
 File size:  1.95 MB
 Viewed:  753 times
 Schwarzes Relais
 File size:  1.55 MB
 Viewed:  732 times
 Schwarzes Relais
 File size:  1.7 MB
 Viewed:  697 times
 Schwarzes Relais
 File size:  1.91 MB
 Viewed:  674 times
Translated on 19-09-2026, 9:19.
Post20-08-2025, 17:46    Subject: Quote
Probably discoloration due to heating caused by increased resistance at the switching contacts...
Translated on 19-09-2026, 9:20.
crapSen
2005 Skoda Superb
Post20-08-2025, 18:03    Subject: Quote
dieselschrauber wrote:
Probably discoloration due to heating because of increased resistance at the switching contacts...
Is this something that can be considered normal wear and tear due to high mileage? Or should we continue to investigate the underlying cause?
I actually got a new VDO pre-lift pump, and I believe the blue relay 202 is responsible for controlling the pump.
I have the feeling that it's starting to vibrate again when it's supposed to be idle (not the usual cut-outs, but a general vibration when idle, which was much better after replacing the two relays). Could it be that the old pre-pump is starting to damage the new relay and its contacts again?
Translated on 19-09-2026, 9:21.
Post21-08-2025, 7:05    Subject: Quote
Hi, due to the low cost of the relay, I would only start troubleshooting and measuring the current flow and checking if the relay might be overloaded if the problem recurs.
Translated on 19-09-2026, 9:23.
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts A3 Engine BGU, Jerking/Unstable Idle Gasoline Engine Technology
No new posts Engine Vibration at Idle (ALH) Diesel Engine Technology
