Vehicle Data Recorders: Are They Being Phased Out?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Dieselschrauber Bar
yaya
dieselschrauber likes this.
Post30-01-2026, 14:35    Subject: Vehicle Data Recorders: Are They Being Phased Out? Quote
Hello everyone,
ich bin etwas verblüfft, an den üblichen mit bekannten Orten ist das Etikett nicht mehr vorhanden. GI have checked/verified/tested.
- Flight manual
- under the rear seat bench.
- Spare tire well / area around it.
Is it really true that I have no more chance of finding out which brake pads I need – without having to manually measure and hope that everything fits?
I find it a bit sad.
What is the alternative here?
I haven't been around Volkswagen Group vehicles for too long; this issue doesn't really exist with BMW (or at least not in the same way).
Translated on 10-08-2026, 20:29.
Karma: +649 / -0   Thank you, like it!
Post31-01-2026, 19:20    Subject: Vehicle Data Recorders: Are They Being Phased Out? Quote
Recently, someone brought in a 2019 Fabia, but it also didn't work.
Translated on 10-08-2026, 20:30.
Karma: +1361 / -0   Thank you, like it!
Post01-02-2026, 18:49    Subject: Vehicle Data Recorders: Are They Being Phased Out? Quote
Hi there,
It should actually be glued inside the owner's manual or in the spare tire compartment.
If not, have it printed out by the dealer.
Translated on 10-08-2026, 20:31.
yaya
Post02-02-2026, 7:29    Subject: Vehicle Data Recorders: Are They Being Phased Out? Quote
Thank you, Herbert & Rüdi.
I inquired with AMAG previously and I'm eager to hear back. I will let you know the result as soon as I have it.
yaya
Post04-02-2026, 20:13    Subject: Vehicle Data Recorders: Are They Being Phased Out? Quote
Update:
AMAG failed to provide the vehicle data carrier, but they did include a printout from Elsaweb via email – which is something, at least.
It's a shame that you have to find out about it later.
Translated on 10-08-2026, 20:32.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Needle Valve: Does it also apply? Diesel Engine Technology
No new posts AGR Problems in the USA? Diesel Engine Technology
No new posts Intercooler for A3 with AGR: Will it fit? Diesel Engine Technology
No new posts 10 Euros - Cents also for SDIs as well? Diesel Engine Technology
