Unlock Vehicle Diagnostic Protection (SFD) (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Post22-04-2026, 14:40    Subject: Unlock Vehicle Diagnostic Protection (SFD) Quote
Unlocking the vehicle diagnostic protection / Unlocking SFD
While we are working on automating the unlocking process, VCDS already supports the unlock and relock procedure using offline unlock tokens.
The following steps are recommended when working on SFD-protected vehicles:
  1. Determine which control units you need to modify, for example:
    • Brake electronics for work on the parking brake.
    • Information electronics for service reset
  2. Check if the diagnostic firewall was disabled when opening the hood.
    Connect to the "Data Bus/Gateway Diagnostic Interface" (#19) and access the Extended Measurements in the Diagnostic Filters section.
    Case A: The filter is NOT active.
    Code:
    IDE13754-MAS16867 Diagnosefilter: Status-Grund für Deaktivierung: Motorhaube offen
    IDE13754-MAS16875 Diagnosefilter: Status-Filterstatus: Filter ist nicht aktiv
    ➔ In this case, you can skip steps 3 and 4. The diagnostic firewall is already disabled.
    Case B: The filter is ACTIVE.
    Code:
    IDE13754-IDE04447 Diagnosefilter: Status-Funktionsstatus: Funktion aktiv: SFD-geschützt
    IDE13754-MAS16875 Diagnosefilter: Status-Filterstatus: Filter aktiv
    ➔ In this case, you must perform steps 3 and 4. The diagnostic firewall is active.
  3. Unlock the "Diagnostics Interface for Data Bus/Gateway" (#19).
    Code:
    MAS18157-MAS18164 SFD-aktivierter Status-Dauer der zu schützenden Fahrzeugdiagnose: 89 Minuten
    Verify that the following measurement displays a number of minutes greater than zero:
  4. (This counts down from zero, after which SFD will be automatically locked again.)
    Disable the diagnostic filter in address #19.
    Typically, you should set the adaptation channel
    Code:
    IDE16611-Diagnosefilter: temporäre Deaktivierung
    from active to inactive.
    Please check this measurement value afterwards:
    Code:
    IDE13754-MAS16866 Diagnosefilter: Status-Kilometerstand: 20 km
    (This counts down from 20 km to zero, after which the filter is automatically re-enabled.)
  5. Unlock (all) additional SFD-protected control units that you want to modify.
Translated on 26-07-2026, 12:42.
Ratings - Unlock Vehicle Diagnostic Protection (SFD)
No new posts Vehicle Diagnostics Protection: Firewall & Filters Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 5E: Unlock Parking Heater Function On-Board Diagnostics (OBD)
