Herbert Profi-Schrauber
28-11-2017, 19:46 Subject: does not exist |
Quote: | | Wie man das Getriebe zerlegt und zusammenbaut steht in der ELSA. Die Frage ist was macht die Seat Werkstatt tatsächlich? |
I know that too.
You are the one raising the issue with the bearing. The question is whether that bearing is actually removed and installed when a housing half is taken off, or if the problem doesn't even exist. To reseal the housing halves, you don't have to disassemble the gearbox into its individual components.
What needs to be done is stated in the ELSA  .
Herbert. Horch A4 8K CJCD
Translated on 11-07-2026, 10:05.
kiter Blaumann
2015 Seat Leon Support
28-11-2017, 20:45 Subject: does not exist |
I would like to know what I should pay attention to after the repair. Or whether one simply accepts the minimal oil leak to avoid expensive problems caused by the repair.
I want to drive the car for at least 250,000 kilometers.
Profile PM Garage |
28-11-2017, 21:24 Subject: does not exist |
Quote: | | I wanted to know what I should pay attention to after the repair. |
Oil leak.
Let's be clear: either you genuinely understand the critical part of the repair and discuss it with the workshop, or you're exaggerating a problem that doesn't exist. Then the workshop will take that very seriously.
If you can't provide any more information about the assembly of the special bearing, then we should probably end the discussion here.
kiter Blaumann
02-01-2018, 18:00 Subject: Transmission |
The critical step after the ELSA procedure is to heat the transmission housing for 10 minutes to a temperature of 100 degrees Celsius, so that the roller bearing does not get damaged during reassembly.
I'm going to put 50 euros into the tip jar and mention that I appreciated the warming, hoping everything goes smoothly.
The repair will be carried out on January 8th. I will provide an update.
Translated on 11-07-2026, 10:06.
Profile PM Garage |
kiter Blaumann
dieselschrauber likes this. |
12-01-2018, 19:35 Subject: transmission; gearbox; gears |
The repair was successfully completed without any further issues. I will report back on how it's doing after 5000 km.
Translated on 11-07-2026, 10:07.
Profile PM Garage |
kiter Blaumann
22-07-2019, 13:50 Subject: does not exist |
After the transmission was resealed, there was a year of peace. Now, in 2019, it's leaking again, but only very slightly. I had expected something like that. I've now sealed it from the outside with epoxy resin. It should last as long as the Ibiza.
Profile PM Garage |
huebi likes this. |
22-07-2019, 18:00 Subject: does not exist |
How does that work? (I know, that's a silly question.) I can only imagine putting a sticker over it.
kiter Blaumann
guste100, Herbert and huebi likes this. |
15-06-2026, 15:01 Subject: does not exist |
@ Herbert
Yes, it's "glued over" and it's still holding up to this day, in 2026!
Profile PM Garage |
