Ignition/Steering Lock: No Return Force When Starting
ronny252
Post16-11-2003, 22:23    Subject: Ignition/Steering Lock: No Return Force When Starting Quote
Perhaps you could give me some tips.
"On my A6 (2.5l TDI, automatic, C4, manufactured in 1995), I have a problem where the ignition key doesn't automatically return to the normal position after starting the engine. This means that without manually turning the key back, the starter would constantly run."
What could be broken there? Is it a spring in the steering wheel lock, or do I just need to replace the switch?
Ronny.
Translated on 29-10-2026, 13:44.
donalexo
Post16-11-2003, 23:04    Subject: Ignition/Steering Lock: No Return Force When Starting Quote
Hello ronny252!
It looks like the return spring in the ignition switch is broken.
Unfortunately, I haven't disassembled an ignition switch before, so I can't assess whether the spring can be replaced and the old ignition switch can be reused.
However, if you follow that product strategy, I believe you'll likely have to replace the entire module, meaning the complete zipper mechanism.
But, as I said, I don't know for sure. Perhaps someone here on the forum can provide you with more expert information about the construction and "repairability" of the ignition switch.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 29-10-2026, 13:46.
ronny252
Post19-11-2003, 22:49    Subject: Ignition/Steering Lock: No Return Force When Starting Quote
Hello Alex,
Thank you for the response. I also suspected a return spring, but where is it located?
In the electrical ignition/starter switch, which is likely just plugged in and probably relatively easy to replace, or perhaps in the mechanics of the steering lock?
Does anyone have any more tips on this?
Thank you and best regards.
Ronny.
Translated on 29-10-2026, 13:47.
PrivatBereich
Post20-11-2003, 10:52    Subject: Ignition/Steering Lock: No Return Force When Starting Quote
I only know about it from Mercedes, where it's located in the dashboard. However, I suspect that VW also installs it in the same location.
Mentally, I would also categorize it there, since it's an electrical condition that the starter motor shouldn't run indefinitely. But, as we know, that doesn't necessarily mean anything.
If you're already mentioning that the switch is so easy to disassemble, I'd like to take it off and have a look at it, or even try replacing it (if the dealer is willing to do that). Alternatively, you could simply ask the dealer for a new one (if they have it in stock) and then try turning it. That way, you'll quickly see if the spring they suspect is actually present inside.
Private.
Translated on 29-10-2026, 13:48.
chrissi
Post20-11-2003, 12:21    Subject: Ignition Switch Electrical Part Quote
Hello everyone,
It is very likely due to the ignition switch, which is an electrical component. However, a few disassembly steps are necessary to replace it. icon_cool.gif
Translated on 29-10-2026, 13:50.
Andy
Post20-11-2003, 12:23    Subject: Ignition/Steering Lock: No Return Force When Starting Quote
The Golf II, Golf III, Passat 35i, and Polo 86C models have the reset mechanism located in the electrical part of the ignition switch.
I'd say there's a 95% chance that your Audi is the same, given the modular construction principle.
Let us know if you break it down.
Best regards, Andy.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Suspension Failure: Allroad Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Pressure Issues When Starting Car Diesel Engine Technology
No new posts 1Z - Sudden RPM drop during startup Diesel Engine Technology
No new posts Metallic noise when starting engine Diesel Engine Technology
No new posts Thick blue smoke on startup Diesel Engine Technology
