HEX-NET connection problems
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
StefanK
1999 Audi A4 Avant Consumption
Post21-07-2026, 10:31    Subject: HEX-NET connection problems Quote
Hello, I have a HEX-NET interface.
Via USB to a Windows 11 computer (tested on two different PCs).
The problem I'm experiencing is that the connection keeps dropping. For example, with a Volkswagen Audi A4 B5 (using the K-line interface). And I'm seeing the same issue with two different cars.
Therefore, it is virtually impossible to pair a key with the WFS because it loses connection after only 5 to 20 seconds.
Unfortunately, adjusting the VP37 using a TDI graph is impossible because it always freezes after just a few seconds.
-> Data for block 000 not available <-
Before I bought the HEX-NET, I always borrowed an older VCDS USB from a friend. I never had any problems with that one...
Thank you in advance for your help!
Translated on 21-07-2026, 10:33.
Post21-07-2026, 11:58    Subject: Subject: Re: Issues with HEX-NET connection Quote
Thank you very much for the help in advance.
It's quite likely that HEX-NET is innocent, and instead the quartz crystals in the vintage cars are drifting out of alignment.
Over time, the bit rates used for communication with each control unit change, and eventually, the difference becomes too large, leading to transmission errors.
When you access a control unit using VCDS, the software displays the communication protocol in the control unit information section at the top left. The moment you enter the control unit information screen, the used bitrate should be displayed. What does it show there?
Edit: Does the HEX-NET have current firmware? Is the HEX-NET connection via Wi-Fi or USB?
Translated on 21-07-2026, 12:05.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.5 TDI AAT Problems: Common Issues & Fixes Diesel Engine Technology
No new posts ABS Problems: Causes and Solutions On-Board Diagnostics (OBD)
No new posts ALE: Troubleshooting GRA Issues in MKB Diesel Engine Technology
No new posts 2.5 TDI +++ Probleme Diesel Engine Technology
