VE Injection Pump Data: 5-Cylinder Engine Performance (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Data
dieselschrauber Post08-08-2026, 21:18
Target data for measurement blocks of 5-cylinder VE engines (distributor injection pump)
Engine codes: AAT (up to 06.94 D14 / from 06.94 D12 / from 07.94 D03) | ACV | AEL | AGX | AHD | AHY | AJT | ANJ | APA
Engine at operating temperature (coolant temperature ≥ 80 °C). LL = idle, VL = full load, - = no specified value. (S) = manual gearbox, (A) = automatic transmission.
Measurement block 0 - Baseline values
MBFDescriptionAAT old LLAAT old VLAAT new LLAAT new VLACV LLACV VLAEL LLAEL VLAGX LLAGX VLAHD LLAHD VLAHY LLAHY VLAJT LLAJT VLANJ LLANJ VLAPA LLAPA VL
01Engine speed36..43140..19033..36 (S) 30..33 (A)140..19036..40142..15233..36 (S) 30..33 (A)140..19235..39145..15535..39142..15236..40140..16036..40140..16035..39142..15235..39142..152
2Start of injection45..60190..21045..60190..2100..88150..20045..60160..2100..98165..2160..98178..20432..85149..2110..88149..2110..98162..2140..98162..214
3Accelerator pedal position0255025502550255025502550255025502550255
4Injection quantity5..25115..1255..25115..12511..45150..1805..25135..15011..35115..14011..35155..19511..45205..22511..45150..17011..35170..21011..35150..170
5Intake manifold pressure-210..235-168..187-167..192-168..194---160..192-180..204-147..177-171..191-152..197
6Atmospheric pressure--------------------
7Coolant temperature80..3680..36--80..3580..35--80..3580..3580..3780..3782..3883..3880..3580..3580..3780..3780..3780..37
8Intake manifold temperature----50..18250..182--53..18283..18253..18283..18253..18353..18350..18253..18353..18283..18253..18283..182
9Fuel temperature----88..19888..198--88..19888..19888..19888..19889..19789..19791..20189..19788..19888..19888..19888..198
10Intake air mass41..75> 18941..75> 18954..111185..23041..75> 18996..136147..186-234..25557..8125569..95195..255----
Measurement block 1 - Baseline values at idle
11Engine speed in RPM750..800 (S) 690..750 (A)740..800750..800 (S) 690..750 (A)740..800740..800740..830740..830740..800740..800
2Injection quantity in mg/stroke2..102.2..92.0..10.02.2..72.2..72.2..92.2..92.2..92.2..9
3Control slide voltage in V1.250..1.7501.25..2.01.25..1.751.25..1.81.25..1.71.25..1.71.4..1.91.25..2.01.25..2.0
4Coolant temperature in °C80..11080..11080..11080..11080..11080..11080..11080..110
Measurement block 2 - Operating state at idle
21Engine speed in RPM750..800 (S) 690..750 (A)740..800750..800 (S) 690..750 (A)740..800740..800740..830740..830740..800740..800
2Accelerator pedal position in %000000000
3Operating state010010010010010010010010010
Measurement block 3 - Air masses / EGR at idle
31Engine speed in RPM750..800 (S) 690..750 (A)740..800750..800 (S) 690..750 (A)740..800740..800740..830740..830740..800740..800
2Air mass setpoint in mg/stroke210..370-210..370230..320230..320190..270230..320200..380250..420
3Actual air mass in mg/stroke210..370-210..370230..320230..320190..270230..320200..380250..420
4EGR valve duty cycle in %14..75-14..754..954..9510..9410..9425..7520..80
Measurement block 4 - Start of injection
41Engine speed in RPM750..800 (S) 690..750 (A)740..8002900..3100750..800 (S) 690..750 (A)740..8002900..3100740..8002800..3100740..8302850..3150740..8302850..3150740..8002800..3200740..8002800..3200
2Start of injection setpoint2°BTDC..1°ATDC3.8°BTDC..0.5°ATDC9..14°crank angle2°BTDC..1°ATDC4.8°BTDC..3°ATDC10..14°BTDC4.8°BTDC..3°ATDC11..13°BTDC3.8°BTDC..0.5°ATDC9..15°crank angle4.8°BTDC..3°ATDC9..15°crank angle4.8°BTDC..3°ATDC10..14°BTDC4.8°BTDC..3°ATDC10..14°BTDC
3Actual start of injection2°BTDC..1°ATDC3.8°BTDC..0.5°ATDC9..14°crank angle2°BTDC..1°ATDC4.8°BTDC..3°ATDC10..14°BTDC4.8°BTDC..3°ATDC11..13°BTDC3.8°BTDC..0.5°ATDC9..15°crank angle4.8°BTDC..3°ATDC9..15°crank angle4.8°BTDC..3°ATDC10..14°BTDC4.8°BTDC..3°ATDC10..14°BTDC
4Injection start valve duty cycle4..4015..9515..954..4010..9510..9510..9510..9515..9060..902..5560..9015..9515..9515..9515..95
Measurement block 8 - Injection quantities at full load
81Engine speed in RPM2800..35002900..31002800..35002900..31002900..31002850..31502850..31502800..32002800..3200
2Injection quantity, driver demand in mg/stroke> 4140..45> 4729..3236..4244.5..47.532..3639..4638..41
3Torque limitation in mg/stroke37..4230..3643..4625..2736..3841..4630..3530..3430..46
4Smoke limitation in mg/stroke35..4536..4144..4823..2831..3941..4630..3539..4630..36
Measurement block 10 - Full load boost pressure
101Actual air mass in mg/stroke800..950490..620780..850870..1000650..850700..950830..1050
2Atmospheric pressure in mbar-------
3Intake manifold pressure in mbar1700..1950-1700..19801830..20801500..18001780..19701600..2000
4Accelerator pedal position in %100100100100100100100
Measurement block 11 - Boost pressure control
111Engine speed in RPM2800..35002900..31002800..35002900..31002850..31502850..31502800..32002800..3200
2Boost pressure setpoint in mbar1720..19201700..19501720..19201700..19801830..20801500..18001780..19701600..2000
3Actual boost pressure in mbar1720..19201700..19501720..19201700..19801830..21101500..18001780..19701600..2000
4Boost pressure valve duty cycle in %30..805..9030..805..9050..8050..805..905..90
Measurement block 13 - Smooth running control at idle
131Cylinder 1 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0
2Cylinder 2 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0
3Cylinder 3 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0
4Cylinder 4 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0
Measurement block 14 - Cylinder 5 smooth running control at idle
141Cylinder 5 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0-2.0..+ 2.0
Measurement block 19 - Control slide travel (AGX, AHD, ANJ, APA)
191Control slide travel voltage at start in V0.54..0.880.54..0.880.54..0.880.54..0.88
2Control slide travel voltage at stop in V4.1..4.84.1..4.84.1..4.84.1..4.8
Additional information - AAT control unit identification
AAT 1st version: up to 06.94, data status D14
AAT 2nd version: from 06.94, data status D12
AAT 3rd version: from 07.94, data status D03
Source: community.dieselschrauber.org – Michael II
Translated on 08-08-2026, 22:34.
Ratings - VE Injection Pump Data: 5-Cylinder Engine Performance
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts Measurement Data Blocks: Different Expected Values? Diesel Engine Technology
No new posts MKB AFB: Solldaten & Data Diesel Engine Technology
No new posts T5 AXE: Data Logging & Measurement Block Diesel Engine Technology
No new posts Target data for R 32 engine, BFH On-Board Diagnostics (OBD)
