Passat Oil Pan/Hydraulic Mount Replacement
hansihanson
Post15-08-2026, 15:10    Subject: Passat Oil Pan/Hydraulic Mount Replacement Quote
Hello fellow 3BG enthusiasts.
Volkswagen Passat 3BG, year 2002, 1.9 TDI, 130 hp, AVF engine, 6-speed manual transmission.
vorweg: der Beitrag steht jetzt in den Themen Motor UND Fahrwerk, weil es beides betrifft. Because:
I need help lowering the subframe/stabilizer (chassis) in order to replace the oil pan (engine).
To replace the oil pan and hydraulic mounts, I need to lower the engine cradle. What should I be careful of? I don't have a lift or pit. The oil pan is already loose. I'm not sure if I just need to support the engine cradle and then loosen the three large bolts on the front (left and right, of course). The rear bolts should remain in place to prevent misalignment, according to my current understanding.
Current setup: Car securely jacked up at the front, with the front wheels raised about 1-2 cm above the ground.
Have a jack ready to support the front of the transmission.
"Have a second jack ready to lift the front of the car further (underneath the air conditioning compressor, so you can remove the oil pan)."
With this setup, you can almost get the oil pan out easily. However, there are still 2-4 cm missing, which I need to obtain from the lowered engine mount.
- Does the stabilizer need to be removed? If so, where exactly (is the center sufficient?), and at what point (before or after the mounting bracket screws)?
- What forces should I expect to apply to the stabilizer bar when the wheels are hanging freely (with a height difference of 1.5 cm from the ground)?
- What forces should I anticipate when lowering the generator carrier? I assume a jack needs to be placed under the carrier and used to carefully lower it after loosening the two 3-bolt fasteners?
Horror scenario:
"I can't get the bracket attached with the 2x3 screws anymore, and I can't center the stabilizer bar because the screw holes no longer align. The car is now immobile and I had to stop and finish the job in my garage."
Da ich auch die Hydrolager wechseln muss, wäre das ja die gleiche Arbeit --> Aggregatträger unten, Motor abgestützt, Lager tauschen, fertig. StWhat does that mean?
"I'm sure some of you have already gone through this. Can you encourage me? Are there any tips you can offer? Where are the potential pitfalls?"
Thank you for your help.
Translated on 15-08-2026, 15:18.
hansihanson
Post16-08-2026, 8:16    Subject: Topic Completed: Task Done & Resolved ✅ Quote
Edit: Done. It's not a problem at all to attach and detach the carrier and stabilizer.
Translated on 16-08-2026, 8:17.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Doku Passat MKB AVB, Kraftstoffverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B: Kat vom 110 PS TDI an den 115 PS PD TDI? Diesel Engine Technology
No new posts MFL Passat 3BG Electrical Systems, Vehicle Electronics, Multimedia
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3C sunroof Transmission, Chassis, Body & Interior
