VW T5.2 CAAC Error P0087: Causes & Fixes
herrtaush
dieselschrauber likes this.
Post02-09-2026, 19:39    Subject: VW T5.2 CAAC Error P0087: Causes & Fixes Quote
Hello everyone,
ich bin mit dem Fehler p0087 stehen geblieben. Der Bus lief bisher einwandfrei, es ging der Glühwedel im Cockpit an dann blieb er stehen. Im Fehlerspeicher war p0087 hinterlegt. Könnt ihr mir bei der Fehlersuche beiseite stehen, VCDS habe ich heute erhalten. WSure, no problem.
Christian.
Translated on 02-09-2026, 19:40.
Post02-09-2026, 20:27    Subject: VW T5.2 CAAC Error P0087: Causes & Fixes Quote
Welcome, you're very welcome! Please post an Autoscan.
Translated on 02-09-2026, 20:28.
herrtaush
Post03-09-2026, 6:00    Subject: VW T5.2 CAAC Error P0087: Causes & Fixes Quote
Hello Reiner,
Thank you for the uncomplicated and friendly welcome!
Attached is the Autoscan.
Christian.
Log-AUTOSCAN-WV1ZZZ7HZCH006719-191230km.txt
 File name:  Log-AUTOSCAN-WV1ZZZ7HZCH006719-191230km.txt
 File size:  16.21 KB
 Downloaded:  71 times
Translated on 03-09-2026, 7:09.
Post03-09-2026, 7:09    Subject: VW T5.2 CAAC Error P0087: Causes & Fixes Quote
Pure
Rainer.
https://community.dieselschrauber.org/en/viewtopic.php?t=31991&highlight=p0087
Translated on 03-09-2026, 7:53.
herrtaush
Post03-09-2026, 14:45    Subject: VW T5.2 CAAC Error P0087: Causes & Fixes Quote
Understood the note, but I still have a question:
When the ignition is on, the N290 continuously hums and vibrates. When the ignition is off, it hums for approximately 30 seconds.
2. When the car is off, should the values for things like "fuel pressure" in VCDS be close to 0?
Christian.
Translated on 03-09-2026, 14:46.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CAAC 2.0 CRDI Injector Noise / Valve Rattle Diesel Engine Technology
No new posts CAAC shuddering between 1700 and 2000 RPM, only above 65%... Diesel Engine Technology
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
