SFD Affected Vehicles: Brands & Models
Karma: +802 / -0   Thank you, like it!
Herbert likes this.
Post21-10-2026, 15:00    Subject: SFD Affected Vehicles: Brands & Models Quote
SFD affects vehicles from the Volkswagen Group, starting around 2019/2020.
Betroffen sind Audi, Cupra, Seat, Skoda, VW und die Nutzfahrzeuge. Platforms:
Golf 8, the ID. models, and other MQB-evo platform vehicles.
Important for practical application: not every vehicle from 2019 is affected. A model with an older platform might be exempt, while a newer model of the same series might not. The question is not just the year of manufacture, but whether the vehicle's control unit uses the SFD (Software-Defined Data) technology.
See SFD Checker:
https://shop.dieselschrauber.org/en/sfd-checker.php
For the workshop, this means: check first, then proceed. A complex coding attempt without prior authorization will fail, and that wastes time.
https://shop.dieselschrauber.org/en/vcds-sfd-abo-p-367.php
Discussion of vehicles affected in the board meeting:
https://community.dieselschrauber.org/en/viewtopic.php?t=31009
Translated on 21-10-2026, 15:02.
No new posts Doku alle VAG Fahrzeuge MJ 2002, Kühlmittelverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD Models: Which are the best? Diesel Engine Technology
No new posts Which PDEs are identical? Diesel Engine Technology
No new posts Which light bulbs are the right ones ??? Diesel Engine Technology
No new posts Best Spark Plugs: Value & Performance Diesel Engine Technology
