DIY Projects: What are you building?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Dieselschrauber Bar
Post22-11-2026, 14:54    Subject: DIY Projects: What are you building? Quote
Das hier ist kein Thema für fertige Autos und Hochglanz-Vorstellungen. Hier geht's um das, was gerade auf der Bühne, im Carport oder auf dem Hof steht, auch wenn es noch zerlegt ist. GRight then.
Just write:
- What is it? A car, a scooter, a lawnmower, it doesn't matter.
- What are you working on right now?
- What's running, what's stuck, and what's still missing?
- Photo of the current condition. A phone picture is sufficient; workshop messiness is explicitly allowed.
"Oil change and a beer."
And if you see something from someone that interests you, a thumbs-up or a sentence is enough. No one is obligated to provide a professional response here, but they can if they choose.
So, what's on your mind right now?
Translated on 22-11-2026, 14:55.
Karma: +594 / -0   Thank you, like it!
dieselschrauber and Hutfahrer likes this.
Post22-11-2026, 18:45    Subject: DIY Projects: What are you building? Quote
Currently, everything is running smoothly for me: cars, motorcycles, lawnmowers, and tractors.
The last thing I did was work on the motor of my electric bicycle.
There's a stupid connector in there, a type used in compact plugs.
"There are always problems with this. It's a known issue; somehow, unsuitable materials are being used that are incompatible with each other. They may even be releasing chemicals that exacerbate the problem. You can see in the picture that the pins are discolored black, specifically in the contact area."
After disassembling the motor four times and cleaning the contacts,
I've bridged all of that now.
Okay, let's see if the motor works reliably now. Otherwise, I'm completely satisfied with it.
 File size:  1.14 MB
 Viewed:  62 times
 File size:  227.08 KB
 Viewed:  64 times
Translated on 22-11-2026, 21:33.
Karma: +648 / -0   Thank you, like it!
huebi likes this.
Post24-11-2026, 5:11    Subject: DIY Projects: What are you building? Quote
"I bought an A6 4f Allroad 3.0 TDI, knowing that the DPF and AGR systems had been reprogrammed... The seller "forgot" to tell me that there was an ongoing recall related to the Dieselgate scandal... I managed to get a significant refund, but now I have to deal with this whole situation."
Translated on 24-11-2026, 9:38.
No new posts Steering wheel not straight when driving straight Transmission, Chassis, Body & Interior
No new posts Damn, just a crack in the rubber hose to the power steeri... Diesel Engine Technology
