Hello community,
"I performed a MotorCheckUp during the last two (and first two) oil changes on my Passat (2.0 TDI, 110kW, DTSB), and both times (after 30,000 km and 10,000 km), a very high soot content was detected, but the fuel dilution was consistent with the oil's mileage; the reports are attached."
The first oil change is to be performed immediately after purchase. There are no relevant errors stored in the system.
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation, without any explanations. If I notice any missing information, I will simply point it out.
Okay, here are the questions:
-Is this perhaps normal for these engines?
- How much does it depend on the driving style?
-The report suggests checking the fuel injectors and turbocharger, but could the injectors be the problem if the fuel injection seems normal? And could the turbocharger be the issue even though there are no error codes related to boost pressure?
-What do you recommend?
Thank you very much in advance.
| Description: |
| High Soot in Engine Oil: EA288 evo |
 Download |
| File name: |
260808_169460_MotorChekUp_1.pdf |
| File size: |
1.25 MB |
| Downloaded: |
1 times |
| Description: |
 Download |
| File name: |
261030_180183_MotorCheckUp_1.pdf |
| File size: |
1.25 MB |
| Downloaded: |
1 times |
Translated on 25-11-2026, 19:04.
