High Soot in Engine Oil: EA288 evo
phgraf
Avatar-phgraf
2022 Volkswagen Passat
Post25-11-2026, 19:02    Subject: High Soot in Engine Oil: EA288 evo Quote
Hello community,
"I performed a MotorCheckUp during the last two (and first two) oil changes on my Passat (2.0 TDI, 110kW, DTSB), and both times (after 30,000 km and 10,000 km), a very high soot content was detected, but the fuel dilution was consistent with the oil's mileage; the reports are attached."
The first oil change is to be performed immediately after purchase. There are no relevant errors stored in the system.
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation, without any explanations. If I notice any missing information, I will simply point it out.
Okay, here are the questions:
-Is this perhaps normal for these engines?
- How much does it depend on the driving style?
-The report suggests checking the fuel injectors and turbocharger, but could the injectors be the problem if the fuel injection seems normal? And could the turbocharger be the issue even though there are no error codes related to boost pressure?
-What do you recommend?
Thank you very much in advance.
260808_169460_MotorChekUp_1.pdf
 File name:  260808_169460_MotorChekUp_1.pdf
 File size:  1.25 MB
 Downloaded:  18 times
261030_180183_MotorCheckUp_1.pdf
 File name:  261030_180183_MotorCheckUp_1.pdf
 File size:  1.25 MB
 Downloaded:  13 times
Translated on 25-11-2026, 19:04.
Karma: +807 / -0   Thank you, like it!
Post25-11-2026, 19:59    Subject: High Soot in Engine Oil: EA288 evo Quote
You don't wait that long for an oil change if you care about engine wear.
Regarding the soot level at 10,000 km since the last change: It's likely that the long-life intervals were already stretched to their limit, and possibly even exceeded, before this.
If the inside of the engine is already black with a thick, sticky layer, then the new oil will quickly become full of soot again.
Can you tell me something about your changing intervals?
Translated on 25-11-2026, 20:01.
phgraf
Avatar-phgraf
dieselschrauber likes this.
Post25-11-2026, 20:04    Subject: High Soot in Engine Oil: EA288 evo Quote
Yes, sure. As I mentioned, the oil change was done immediately after reaching 30,000 kilometers; unfortunately, many people, including the previous owner it seems, believe the promises of the "LongLife" oil.
I'm now changing the oil every 10,000 miles.
Translated on 25-11-2026, 20:05.
Post25-11-2026, 20:15    Subject: High Soot in Engine Oil: EA288 evo Quote
phgraf wrote:
Yes, gladly. As I said, the oil change after 30,000 km was done immediately after purchase; unfortunately, many people, including the previous owner it seems, believe the promises of LongLife oil.
I am now changing every 10,000 miles.
I find 10,000 km a bit short, but it might make sense for an engine that's very dirty.
Also, also pay attention to the oil as well; more expensive doesn't necessarily mean better, choose the right oil.
I've also noticed significant differences in the oil, seeing what came out during changes. I ended up sticking with a product that proved to be reliable.
Translated on 25-11-2026, 20:17.
phgraf
Avatar-phgraf
Post25-11-2026, 20:22    Subject: High Soot in Engine Oil: EA288 evo Quote
Thanks for your assessment; that makes sense regarding the sludge buildup. I've been hesitant about engine flushes so far, what do you think about them?
I use Fuchs or Mannol oil.
May I ask what you mean by differences in the appearance of the oil? I always see diesel oil as a deep black, regardless of the engine or the type of oil.
Translated on 25-11-2026, 20:23.
phgraf likes this.
Post25-11-2026, 20:24    Subject: High Soot in Engine Oil: EA288 evo Quote
PS: It's a good idea to check the turbocharger intercooler system for leaks. If there's a leak, the engine will produce a lot of soot, which you might only notice through the DPF if the regeneration intervals are unusually short.
Translated on 25-11-2026, 20:24.
Karma: +1359 / -0   Thank you, like it!
Post25-11-2026, 20:42    Subject: EA288 evo: High soot content in engine oil Quote
phgraf wrote:
Hello community,
"During the last two (and first two) oil changes on my Passat (2.0 TDI, 110kW, DTSB), I performed a motor check-up each time, and both times (after 30,000 km and 10,000 km), a very high soot content was detected."
regards
How was the checkup performed? What measurements were taken?
Translated on 25-11-2026, 20:43.
Post25-11-2026, 20:45    Subject: High Soot in Engine Oil: EA288 evo Quote
Is this it?
https://shop.motorschadenvergleich.de/?srsltid=AYCX9vJgw8e9WIt_7SMvDwmGc4qnHAwpDusacFMZ1RAi5shNeXLIeSps
Translated on 25-11-2026, 20:46.
phgraf
Avatar-phgraf
Post25-11-2026, 21:04    Subject: High Soot in Engine Oil: EA288 evo Quote
I'm not exactly sure how it's evaluated, I just put a drop on a test strip and send it in.
I assume that the evaluation is purely visual, but performed by a machine.
Translated on 25-11-2026, 21:04.
Post26-11-2026, 8:00    Subject: High Soot in Engine Oil: EA288 evo Quote
You ask at the beginning of the topic what we recommend.
In my opinion, oil changes should be performed according to the service indicator, and the oil quality should meet the manufacturer's specifications. You can be confident with oils from major manufacturers, but I would have reservations about oils sold in supermarkets.
In addition, at what kilometer intervals does the regeneration process occur? What is the fuel consumption, and what is the registered soot level of the oil displayed on the instrument cluster after approximately 10,000 km and 20,000 km?
My CJCD requires an oil change only after 30,000 km, even under high engine load (approximately 25% of the kilometers driven on holiday trips with a caravan). For the DDYA engine, I change the oil after 15,000 km due to oil buildup.
Translated on 26-11-2026, 8:02.
phgraf
Avatar-phgraf
Post26-11-2026, 8:56    Subject: High Soot in Engine Oil: EA288 evo Quote
I don't have a soot sensor in my car, and I change the oil at a fixed interval (10,000 km) rather than based on a warning light. Of course, I use the correct oil specification.
Fuel consumption: 4.8 liters in the summer, now 5 liters.
Driving profile: 50% long-distance driving, with an average distance of 420 km at an average speed of 94 km/h, including approximately 300 km on the highway with a mostly 130 km/h cruise control setting.
The remaining 50% consists mainly of short- and medium-distance routes.
I almost always drive as fuel-efficiently as possible, using the "free wheeling" function whenever possible. Low-speed driving and short trips likely contribute to soot emissions to some extent, but I don't think they explain the extent of the problem. I find Rainer's explanations to be plausible.
What do you mean by "WW"?
Okay, please provide the German text you would like me to translate.
Translated on 26-11-2026, 8:58.
Post26-11-2026, 10:12    Subject: High Soot in Engine Oil: EA288 evo Quote
WW stands for "wohnwagen" (caravan). Of course, you can find the soot load of the current interval in the instrument cluster control unit using VCDS, in increments of 10,000 kilometers. A fuel consumption of 4.8 to 5 liters is very good, and I would like to achieve that. Based on the driving profile, I don't see any extraordinary soot load. What do you mean by "freelauf"?
You don't say anything about the regeneration intervals.
Of course, you want to find something, which is why this obscure test exists.
Translated on 26-11-2026, 10:15.
phgraf
Avatar-phgraf
Post26-11-2026, 12:07    Subject: High Soot in Engine Oil: EA288 evo Quote
Okay, I thought you meant that the AI was directly integrated into the display.
VW refers to the function where the DSG automatically disengages the gear, allowing the car to roll freely, as "Freilauf."
I haven't watched "Regenerations" yet, but I plan to.
Translated on 26-11-2026, 13:36.
No new posts Debris and fragments in engine oil bind General Tips
No new posts Audi A3 (8L): High Mileage Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel in Engine Oil: Causes and Solutions. Diesel Engine Technology
No new posts EA288 2L CR Engine Block Diesel Engine Technology
No new posts Oil temperature increases after heat exchanger replacemen... Diesel Engine Technology
No new posts Motor oil for PD with WIV? Diesel Engine Technology
