Is it harmful to warm up a car with the heater turned off?
joegolf
Post25-11-2003, 14:02    Subject: Is it harmful to warm up a car with the heater turned off? Quote
Given the relatively cold temperatures this time of year, I've gotten into the habit of turning off the heater until the engine reaches around 70-80°C as indicated on the display.
The engine gets noticeably warmer, my fuel consumption decreases on my route (30km) by 5-10%, and I can easily do without the cold air at the beginning.
But: Is this somehow harmful to the engine? Could the faster heating, for example, damage the cylinder head gasket (due to different expansion of the engine block and cylinder head)? Or could there be any other problems?
Gremlin
Post25-11-2003, 14:55    Subject: Is it harmful to warm up a car with the heater turned off? Quote
problem 1 (less severe): you are cold
problem 2 (very bad): your wife/girlfriend/someone else is cold
-> What do you do when the engine starts on a hot summer day?
question answered?
See you, Gremlin
Julian
Post25-11-2003, 15:03    Subject: Is it harmful to warm up a car with the heater turned off? Quote
Problem 1.5 (good for the engine): You're getting a cold in the cold interior and leaving the car running! icon_wink.gif
joegolf
Post25-11-2003, 18:54    Subject: Is it harmful to warm up a car with the heater turned off? Quote
Gremlin wrote:
problem 1 (less severe): you're cold
question answered?
See you, Gremlin
Problem 1: I also get cold even when the heating is on. In fact, I get colder, because it gets really drafty when the engine is cold. That's why I don't mind.
And because the engine heats up faster when it is first turned off, it actually results in warmer air coming out sooner.
Problem 2: I take it and put it in my warm right arm. icon_biggrin.gif
During the peak summer months, the engine's temperature rises. Whether it's going from 20°C or 10°C to 90°C might not make a significant difference. But what about at -10°C?
Well, then I'll just keep going. And if the ZKD expires, I will sue you. icon_razz.gif icon_biggrin.gif icon_cool.gif
Julian
Post25-11-2003, 19:07    Subject: Is it harmful to warm up a car with the heater turned off? Quote
Hm, dann solltest du mir so schnell wie möglich eine Rechnung ausstellen, aber ich glaube kaum, dass du Gremlins und meinen Stundensatz bezahlen könntest.... icon_biggrin.gif
joegolf
Post25-11-2003, 19:12    Subject: Is it harmful to warm up a car with the heater turned off? Quote
Main thing is, it's lower than the VW. Then one could really think about it if needed. icon_biggrin.gif
Gremlin
Post25-11-2003, 20:05    Subject: Is it harmful to warm up a car with the heater turned off? Quote
Forget it...
btw: what about a stand heater?
See you, Gremlin
No new posts Heated, auto-dimming side mirror malfunction General Tips
No new posts P1118 - Oxygen Sensor Heater Circuit Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Cooling: Is it Harmful? Diesel Engine Technology
No new posts Chip Tuning: Harmful at 90,000 km? Diesel Engine Technology
No new posts Custom oil change intervals: harmful? Diesel Engine Technology
No new posts Low RPM Driving: Harmful to Your Engine? Diesel Engine Technology
