G60 Measurement Blocks: Specs & Applications
René_S
Post27-11-2003, 17:34    Subject: G60 Measurement Blocks: Specs & Applications Quote
Hello, I'm planning to measure the boost pressure on a tired Corrado soon. Unfortunately, I don't have any data (measurement blocks/target values). Does anyone have a tip?
Sure, here's the translation:
'Thank you in advance.'
René.
Translated on 28-09-2026, 12:05.
chrissi
Post27-11-2003, 19:28    Subject: G60 Measurement Blocks: Explained & Used Quote
Response from Chrissi:
The G60 is not yet capable of being diagnosed, meaning that it doesn't support features like displaying measurement data blocks, etc.
Translated on 28-09-2026, 12:07.
René_S
Post27-11-2003, 20:32    Subject: G60 Measurement Blocks: Specs & Applications Quote
Thank you for the quick response. How can I test the condition of the charger? Does anyone have experience with overhauling the charger? From what I see on the link below, it seems straightforward... icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif
http://www.g-laderseite.de/g-lader_arbeiten_am_g-lader.php3
René
Arne
Post28-11-2003, 15:37    Subject: G60 Measurement Blocks: Specs & Applications Quote
Hi Renè,
If no one here can help you, check out www.vwcorrado-forum.de.
It's over there. You'll find tons of information and instructions there. You can find it at...
You can even do the G60 calibration with the MFA (Multifunction Display), where the pressure is indicated in millibars.
So, as I said - take a look around and use the search function.
arne
Translated on 28-09-2026, 12:08.
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Measurement blocks 1Z On-Board Diagnostics (OBD)
No new posts Measurement blocks A6 2.5 TDI V6 Diesel Engine Technology
No new posts Measurement blocks On-Board Diagnostics (OBD)
No new posts Measurement values into EDC measurement blocks On-Board Diagnostics (OBD)
