TDII Guest
28-11-2003, 18:26 Subject: Service Interval Display A6 C4 - Customization Options |
Hello everyone,
ich habe heute versucht bei meinem kürzlich erworbenen Audi A6 TDI (MKB: AEL; Mj:96) die Serviceintervallanzeige per VAG-Com zurückzusetzen. In der Fehlerdaten nachgeschaut, habe ich auch die richtigen Werte gefunden. Beim Versuch die Anpassungswerte lt. Ttable
However, the instrument cluster displays an error when attempting to enter values for inspection codes 01 and 02. It only accepts values less than 255. Consequently, attempts to enter values such as 'INS 01 00365' for 365 days or 'INS 02 00730' for 730 days will fail.
Now, my question is:
Are you correct in assuming that 255 corresponds to the maximum number of days that can be entered, and that for INS 01 it is 365?
Do I need to create a calculation for 100 days based on the following formula?
255 / 365 * 100 = 70
Do I have this problem alone, or is the table incorrect for the A6 C4 type?
Thank you in advance.
Best regards, Holger.
Translated on 14-08-2026, 8:08.
28-11-2003, 18:42 Subject: Service Interval Display A6 C4 - Customization Options |
I once read somewhere that you have to enter a value that is one-tenth of the total number of days. So, for 360 days, you would enter 36, and for 720 days, you would enter 72, and so on.
However, it's dangerous to have incomplete knowledge, so it's best to wait for proper confirmation.
January. 1Z5 CFHF  / AHB H4D
Translated on 14-08-2026, 8:10.
Bertil Profi-Schrauber
28-11-2003, 20:00 Subject: Service Interval Display A6 C4 - Customization Options |
Why do you want to enter 365 and 720?
The table actually says 36 and 72 for the C4! (The first table is the one that applies to you!) Gruß Bertil
TDII Guest
29-11-2003, 13:50 Subject: Service Interval Display A6 C4 - Customization Options |
Sorry.
'Whoever can read has a clear advantage! In the heat of the moment, I only glanced at the screen on my computer and then ran into the garage. That's how I memorized the wrong line!'
'Thank you anyway.'
Translated on 14-08-2026, 8:11.
