LMM: Too much air?
Post29-11-2003, 1:36    Subject: LMM: Too much air? Quote
Hi.
I did some test drives today using VAG-COM.
(The test vehicle was a Golf 3 TDI with a 1Z engine, manufactured in December 1995, with 150,000 km on the odometer. At the time of the measurement, the engine had been running for half an hour, and the coolant temperature was consistently 82 degrees Celsius, according to measurement group 7.)
I'm a bit confused about the LM value:
http://people.freenet.de/golf-schrauber/LMM.gif
Higher values on the mass airflow meter (MAF) could potentially be caused by a clogged EGR valve, because if the EGR valve is blocked, the engine might be drawing air from the fresh air intake instead of the EGR system (did you find an answer to this?).
Here https://community.dieselschrauber.org/en/viewtopic.php?t=4459&highlight=lmm+werte, a similar question was asked, but not yet definitively answered.
There are no error entries.
Why does it have so much more air than the EDC wants?
"I think turbo pressure seems more sensible (even though I never really had the time to let it adjust properly because of the traffic...)"
http://people.freenet.de/golf-schrauber/LDD.gif
Translated on 05-09-2026, 13:49.
DocSnydor
Post01-12-2003, 9:55    Subject: LMM: Too much air? Quote
Please read this:
/viewtopic.php?t=2126&highlight=
Translated on 05-09-2026, 13:51.
Post01-12-2003, 10:14    Subject: LMM: Too much air? Quote
That doesn't quite apply to my situation.
I have a Series 1Z (so, one that hasn't been "tampered with" regarding the EGR system).
Why are the values deviating then? Or is my EGR valve unintentionally broken (that's my only explanation).
"Furthermore, during a 1.5-hour test drive yesterday, I noticed that at full throttle, the mass airflow sensor (MAF) value DECREASES above a certain RPM. Up to approximately 3000 RPM, it provides the desired value of 841 mg (with the EGR system already activated, resulting in 4.7% EGR). However, when the engine is revved higher, the MAF value decreases."
Okay, it rained, which could have caused the paper air filter to become clogged... but 740 instead of 840 mg/H at 3300 RPM seems suspicious, right???
I would be happy to upload the measurement data online this evening, if it can be helpful to anyone.
Translated on 05-09-2026, 13:52.
Thomas K.
Post02-12-2003, 14:14    Subject: LMM Behavior: Strange Issues and Solutions Quote
I'm experiencing the same phenomenon with a decreasing mass airflow (MAF) value at higher engine speeds in my Golf IV PD AJM 115PS. During a VW test at full throttle in third gear at 3000 RPM, I measured a value of 911 mg/H. During extended full-throttle driving, the value drops to as low as 800 mg/H at around 3800 RPM.
I'm also not sure whether the mass airflow sensor is malfunctioning or if this behavior is normal.
Translated on 05-09-2026, 13:54.
Gremlin
Post02-12-2003, 15:46    Subject: LMM: Too much air? Quote
theory1:
The flow losses increase more significantly at high speeds than the (already constant) boost pressure can compensate for.
theory2:
The fresh air mass sinks due to increasing intake air temperatures (because the intake pressure remains constant in this case).
CU Gremlin.
Translated on 05-09-2026, 13:55.
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Zuviel Ladedruck: Was kann es noch sein? Diesel Engine Technology
No new posts The Path of the Air. Diesel Engine Technology
No new posts Kalte Luft, Ruß weg!?! Diesel Engine Technology
No new posts Luft in Kupplungshydraulik Diesel Engine Technology
