Where to attach the boost pressure hose
kossmann
2016 Audi Q3
Post20-04-2002, 11:49    Subject: Where to attach the boost pressure hose Quote
Hello everyone,
Where is the best place to tap into the boost pressure for a boost gauge (auxiliary instrument) on a 1Z engine?
A "thick" hose connects to the master cylinder, and two small hoses branch off from it. Can I tap into one of these two hoses, or are they actually charge pressure hoses (which is what I was told)?
Translated on 22-07-2026, 17:34.
Post20-04-2002, 19:11    Subject: Subject: Just don't touch the master cylinder... Quote
You'll only find vacuum at the master cylinder, so that statement is nonsense.
On the 1Z engine, there should be a thin hose running from the turbocharger outlet towards the solenoid valve. Tap into that hose with a T-connector, and you'll have access to the boost pressure.
Translated on 22-07-2026, 17:36.
kossmann
2016 Audi Q3
Post21-04-2002, 11:33    Subject: Where to attach the boost pressure hose Quote
Thank you for the information!
"Do you happen to have a picture of it? There are so many hoses there, and I don't want to accidentally grab the wrong one..."
Translated on 22-07-2026, 17:37.
Post21-04-2002, 12:06    Subject: No photo from the 1Z - can anyone else help? Quote
Do you happen to have a picture of it? There are a lot of hoses there, and I don't necessarily want to grab the wrong one...
No, I have my own AFN (Armed Forces Network) and only know about the 1Z from what I've read.
Translated on 22-07-2026, 17:38.
Post21-04-2002, 20:41    Subject: Boost hose Quote
Above the pipe in front of the cylinder head (intake side), you'll see a small hose that connects to the engine control unit, and that's where the correct boost pressure should be present.
Best regards, Bertil.
Translated on 22-07-2026, 17:39.
kossmann
2016 Audi Q3
Post21-04-2002, 22:04    Subject: Where to attach the boost pressure hose Quote
Okay, I'll look for it tomorrow (when it's light out).
"The idea of using a control unit also occurred to me, but the problem was that I didn't know which cable went where."
Translated on 22-07-2026, 17:40.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts Turbocharger Boost Hose Replacement (AMF) Diesel Engine Technology
No new posts Oily Turbocharger Boost Hose: Causes & Fixes Diesel Engine Technology
No new posts What adhesive should be used to glue a turbocharger boost... Diesel Engine Technology
