Rudi Guest
17-06-2002, 21:52 Subject: Catalytic Converter Recycling: Replacement Pipes |
Since our return trip from vacation this weekend, our car has been exhibiting the following problem:
When starting (fully loaded plus with a Klaufix device), there's a clunking noise coming from the exhaust.
This effect does not occur when the vehicle is unloaded (although it is still somewhat noticeable). When loaded, the vehicle also sits lower than it used to.
I suspect (I haven't had time to put it on a lift yet) that the exhaust pipe is cracked near the catalytic converter (it already looked quite corroded), and that the entire exhaust system is shifting so much when the car is loaded that it could make mechanical contact. Furthermore, the rear shock absorbers will likely need to be replaced sooner or later.
Michael II once wrote something about a 'dislodged monolith' in the catalytic converter, which could explain some unusual noises.
Since a new catalytic converter costs about 330 EUR, I'm wondering if it's possible to recycle the (cleaned) monolith by incorporating it into a replacement catalytic converter pipe.
- Has anyone ever tried something like this before?
- Where can one find decent replacement exhaust pipes for KAT (catalytic converter) systems?
- How much do they cost (is it even worth the effort)?
Translated on 28-10-2026, 12:23.
Bertil Profi-Schrauber
18-06-2002, 8:17 Subject: Clacking Noise: Causes and Solutions |
Hello Rudi,
Here comes the funny part:
Upon my return from vacation (last Friday), I also noticed strange rattling noises coming from the exhaust area! It turned out that only the muffler had detached from the exhaust system, and the best part was that the engine wasn't significantly louder without the muffler.
Shake the end of the tube to see if it feels loose. Gruß Bertil
Translated on 28-10-2026, 12:26.
Rudi Guest
18-06-2002, 8:35 Subject: Catalytic Converter Recycling: Replacement Pipes |
Hello Bertil,
The exhaust pipe was due for replacement back in February  .
I hope to be able to come and watch the game this weekend.
tim27 Guest
18-06-2002, 20:05 Subject: Cat Breeds: Types, Pictures & Information |
If you replace the catalytic converter with a pipe, make sure to install a silencer in between instead of connecting it directly to the exhaust pipe. Otherwise, you will lose power because you will be missing some back pressure.
For example, go from a diameter of 60mm to approximately 50mm, then back to 60mm, and it should work.
Good luck.
Translated on 28-10-2026, 12:27.
Rudi Guest
18-06-2002, 21:06 Subject: Catalytic Converter Recycling: Replacement Pipes |
Hello Tim,
The idea with the pipe isn't bad, but (unfortunately) it's illegal  .
I was thinking about getting a cat, but I don't want to spend over 300 EUR. A cat simulator would probably cost somewhere between 50 and 100 EUR (I haven't found anything specific for TDi's yet).
Then cut it open, remove the contents, insert the old monolith, and weld it back together.
Translated on 28-10-2026, 12:28.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
19-06-2002, 9:59 Subject: Catalytic Converter Recycling: Replacement Pipes |
Hello Rudi,
I drive past a company every morning here in Nuremberg that installs/sells aftermarket/replacement catalytic converters. I'll go check it out during my lunch break.
Translated on 28-10-2026, 12:29.
Profile PM WWW Garage |
Rudi Guest
19-06-2002, 10:19 Subject: Catalytic Converter Recycling: Replacement Pipes |
Great!
'Thank you very much!'
19-06-2002, 12:24 Subject: Catalytic Converter Recycling: Replacement Pipes |
Hello Rudi,
The company is only a Bosch service center  that retrofits catalytic converters.
The company sells KATs, among other products, from the company GAT http://www.gat-kat.de/.
According to their expert, there are different G3 variants with a 1Z configuration, each featuring a different bracket.
On the GAT company website, there is one catalytic converter available for the G3 Variant 1Z model, priced at 280 euros plus VAT.
Translated on 28-10-2026, 12:30.
Rudi Guest
19-06-2002, 13:11 Subject: Catalytic Converter Recycling: Replacement Pipes |
Hmph...
That's almost the same price level as VAG.
Nevertheless, thank you very much for your effort.
Translated on 28-10-2026, 12:31.
Mtw13ve Guest
19-06-2002, 22:06 Subject: Catalytic Converter Recycling: Replacement Pipes |
Just do it like I did... Eventually, I knocked out all the junk that was stuck in the catalytic converter using a hammer and chisel. Then, it was game over. Once I got it to rev up, all the debris came flying out. LOL.
Since then, I've been driving around with a completely empty catalytic converter! But be careful... it makes a terrible noise!
I should also mention that my catalytic converter was loose and was constantly clogging the exhaust, which is why I took that action.
cu
chris
Translated on 28-10-2026, 12:32.
konjoy Guest
07-12-2003, 14:57 Subject: Catalytic Converter Recycling: Replacement Pipes |
Question for Mtw13ve: Does the car now really produce a lot of exhaust smoke without a catalytic converter?
And what about power consumption, performance, and noise levels?
Translated on 28-10-2026, 12:33.
