Where can I find the coolant temperature sensor G62?
hueso
Post19-11-2003, 19:04    Subject: Where can I find the coolant temperature sensor G62? Quote
I drive a VW Bora 1.9 TDI PD (AJM) and I'm experiencing a problem where the engine revs up briefly after starting. I've found through online searches that this is likely related to the G62 sensor. Where can I find this sensor? When the engine is warm, it also starts poorly; is that related?
Best regards, Hüso.
hueso
Post20-11-2003, 18:25    Subject: Where can I find the coolant temperature sensor G62? Quote
It's me again, does anyone know where I can find a parts catalog online? The link here on the board is no longer working!
Best regards, Hüso.
decell
Post10-12-2003, 15:13    Subject: Where can I find the coolant temperature sensor G62? Quote
'I had the same problem: The engine always seemed to be in pre-glow mode (even when the engine was already warm), and the RPM would jump to around 1500-2000 when starting a warm engine. The G62 sensor is located on the AJM engine, hidden below the cylinder head behind the plastic cover. There are 4 wires connected to this sensor. It's a bit difficult to find, but if you follow the coolant hoses, you'll find it.' I think that part cost around 25 euros.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Geber für Kühlmitteltemperatur On-Board Diagnostics (OBD)
No new posts Geber für Kühlmitteltemperatur beim Golf III Diesel Engine Technology
No new posts Finding an OT with a multimeter. Diesel Engine Technology
No new posts Kühlmitteltemperatur AMF Diesel Engine Technology
