gra stoppt nicht bei kupplungsbetätigung | Posts 16+
Go to page: Previous  1, 2
marki
Post26-06-2002, 17:07    Subject: Quote
icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Hello there!
Just came from the workshop.
A very big thank you is definitely in order now!
THANK YOU TO EVERYONE.
The control unit was actually designed to cooperate with an automatic transmission.
The code was swapped and the signal from the clutch switch was reused – everything is working perfectly now! Great!
to the lmm
Unfortunately, I was unable to print the measurement data blocks. They didn't have a printer there, nor did they have a working disk drive.
Unfortunately, I was only able to sporadically compare the actual values with the target values from your database.
The diagnostic device had organized the measurement data differently, and I could only use it for a short time.
The only thing I noticed was the injection start timing: 3.5 degrees. In the actual data listed on your forum, it's specified as 12.75.
Does anyone have any ideas on how I can proceed from here?
Best regards.
marki
Translated on 29-07-2026, 10:06.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Stalls at High RPM: 3.3 CR-TDI Issues Upload
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Car won't start, lights not working Diesel Engine Technology
