Großer Turbo im A4/ Passat, AFN, AJM alle mit Serien VNT 15 | Posts 16+
Go to page: Previous  1, 2
Thomas
Post12-12-2003, 15:54    Subject: Quote
"It's a shame I'm only seeing this now, but I don't necessarily find it so appealing that I would want to find my photos in your PDF. Some passages of the text also seem quite familiar to me..." icon_rolleyes.gif
You could have at least asked.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 24-10-2026, 20:56.
Manuel Thomas
Post12-12-2003, 16:08    Subject: Quote
@ Thomas
I emailed you and sent you an ICQ message, but you haven't responded!
And since you emailed me that picture about a year ago, I assumed you wouldn't mind!
But I didn't 'steal' any text passages from you!
Manuel.
Thomas
Post12-12-2003, 16:54    Subject: Quote
You asked me via ICQ if I still had the part number or the picture of that hose. In response, I sent you an email with the following picture and a text that essentially pointed out that this hose is not only more suitable for the project but also cheaper. It only costs about 50 euros.
But dwelling on it further now would probably not be helpful. Let's just leave it as it is.
The easiest solution would be to simply obtain a GT1749V turbocharger with the same compressor outlet as the VNT15, which would avoid all the potential problems.
The part number for this turbocharger is: 028 145 702 R.
It is important to ensure that the turbocharger is a GT1749V "A" or V "B" model. Both "A" and "B" have modified internal components.
The "B" version is ONLY available at ARL and can ONLY be used with a manifold. With this version, as with the GT1749V with a manifold, there is a problem: if the turbocharger is mounted on an AFN engine, the compressor housing will interfere with the aluminum engine mount and the pressure sensor on the hydrostatic bearing.
Part numbers "A": (Compressor outlet, as shown in the PDF).
038 145 702E
Part number "B": (Compressor outlet for silencer).
038253019G or 038253019D.
Greetings.
Thomas.
PS: The AJM, ... also has a GT 17!
 File size:  59.17 KB
 Viewed:  9797 times
Translated on 24-10-2026, 20:59.
No new posts Interesting for all Passat owners from 1996 onwards. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG Vehicles 2002: Coolant Leak Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Longlife Service: Every 15,000 km? On-Board Diagnostics (OBD)
No new posts GRA Defect: Troubleshooting TV Series Issues Diesel Engine Technology
No new posts Serial charging pressure for the 1Z Diesel Engine Technology
No new posts STG Glitches Every 3 Minutes Diesel Engine Technology
