dcjf Guest
11-12-2003, 11:56 Subject: Climate control channels 8 and 10 - Enter actual values directly |
Oh yes, and the problem I described earlier with the air control flap had nothing to do with what I suspected. The flap responsible for controlling the amount of outside air that passes through the heating radiator is called the temperature control flap. In channel 10c, you can query the setpoint value. The smaller the number, the more air is directed directly through the heating radiator. For me, the setting is at 20 (warm) and 248 (cold).
What was new to me, and what I hadn't seen in any documentation for climate control codes: If a channel is displayed with its actual value (for the temperature flap, this is channel 8c), then – and only then – can the actual value be changed using the +/- buttons for fan control. At this moment, the automatic control for this channel is obviously overridden.
Operating channel 8 is exactly the same as operating the temperature control on a conventional heating system. The only difference is that at the maximum setting... Do not close the heating valve when it is cold.
Or did you already know all of this?
Translated on 05-07-2026, 18:58.
PowerSound3L Guest
11-12-2003, 16:21 Subject: Climate control channels 8 and 10 - Enter actual values directly |
hello,
No, I didn't know that.
but do I need it?
Did you know that you can perform a basic setting on the Climatronic system by selecting channel 000 in the basic settings?
where does it determine the positions of the valves and relearn the end values?
greetings
Translated on 05-07-2026, 19:00.
dcjf Guest
11-12-2003, 18:28 Subject: Climate control channels 8 and 10 - Enter actual values directly |
<Pardon>
Yes, I knew that it's possible to perform a basic adjustment where the flaps are moved from fully open to fully closed.
But: Does this also work (only) with the Climatronic control panel?
Translated on 05-07-2026, 19:01.
chris40 Guest
12-12-2003, 12:18 Subject: Climatronic default setting |
Well, how exactly does that work with the Climatronic control panel?
dcjf Guest
12-12-2003, 17:37 Subject: Climate control channels 8 and 10 - Enter actual values directly |
Oops, I accidentally started a new thread. For those who want to know the background story:
chris40 Guest
16-12-2003, 12:11 Subject: Climate control channels 8 and 10 - Enter actual values directly |
Okay, but the link unfortunately doesn't work.
Perhaps you could briefly describe the keyboard shortcut for the reset.
Best regards, Christian.
Translated on 05-07-2026, 19:02.
dcjf Guest
16-12-2003, 12:20 Subject: Climate control channels 8 and 10 - Enter actual values directly |
Hello Christian,
As I said, I don't know if this will work with the control panel. However, for example, the temperature control flap can be manually adjusted using channel 10, while the recirculation air flap can be adjusted using channel 16.
Okay, this link should work now.
Translated on 05-07-2026, 19:03.
