AAT Motor
Trecker Treiber
Post15-10-2003, 21:11    Subject: AAT Motor Quote
I have a question.
Are the fuel injectors of the AAT engine the same as those of the AEL icon_question.gif?
olli
Karma: +46 / -0   Thank you, like it!
Post15-10-2003, 22:27    Subject: AAT Motor Quote
No, they are not.
Try it at http://www.bosch-automotive.com/ecat-online/.
Here are the part numbers.
Olli.
christians
Post16-10-2003, 11:35    Subject: AAT Motor Quote
The AEL, unlike the AAT, has 5-hole nozzles.
Gruß Christian
Trecker Treiber
Post16-10-2003, 17:25    Subject: AAT Motor Quote
Thank you for the information.
christians
Post17-12-2003, 11:29    Subject: AAT Motor Quote
Late correction: The AEL nozzles with five holes have a more rounded bore design, which provides higher flow rates while maintaining the same atomization quality. They both have five holes.
Gruß Christian
Andi aus dem Ösiland
Post17-12-2003, 12:04    Subject: Is a trade possible? Quote
Hi!
So, theoretically, you should be able to swap the AAT (Airflow Temperature) sensors with the AEL (Air-Fuel Ratio) sensors to potentially achieve a slight increase in performance, right?
Does anyone happen to have a photo of an AAT and an AEL piston?
Andi.
christians
Post17-12-2003, 12:37    Subject: AAT Motor Quote
Of course, the Audi brochure from 1994/95 didn't go into much detail about the shape of the pistons. They are more likely to fit in the A6's AAT (air intake manifold) than in the Audi 100's.
Gruß Christian
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts AEL engine in T4 - Ex-ACV Diesel Engine Technology
