Needle Valve Injector (20-12-2003, 23:28)
df16225
Post20-12-2003, 23:28    Subject: Needle Valve Injector Quote
hello,
Can someone explain to me how a faulty needle lift valve affects the 1Z engine?
'Additionally, I'm experiencing a constant rattling sound at approximately 1400 RPM. Could this be related to the vibration damper on the crankshaft? What could be the cause?'
Dirk
Translated on 14-10-2026, 16:59.
Post21-12-2003, 0:04    Subject: Needle Valve Actuator: Explained & Optimized Quote
df16225 wrote:
Can someone explain to me how a faulty needle lift solenoid affects the 1Z engine?
Yes, we could explain it to you – as the approximately 764th person asking, and we would have to write the same text to everyone.
To save you the trouble, we've compiled a comprehensive collection of articles – and it seems you may have overlooked the link to the search function.
Furthermore, I'm experiencing a constant rattling sound at approximately 1400 RPM. Could this be related to the vibration damper on the crankshaft?? What could be the cause?
Among other things, the needle injection system...
Translated on 14-10-2026, 17:00.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Needle driver On-Board Diagnostics (OBD)
No new posts Needle Valve: Types, Function & Applications Diesel Engine Technology
No new posts 1Z Needle Valve Actuator in ASV ??? Diesel Engine Technology
No new posts Needle Valve: Does it also apply? Diesel Engine Technology
