Volvo V70: Loud Engine Knocking - What to Do?
batman
Post08-01-2004, 8:33    Subject: Volvo V70: Loud Engine Knocking - What to Do? Quote
Hello everyone, the engine in my V70 (5-cylinder) is much louder than the identical engine in my colleague's Audi A6. Since they are identical engines, the knocking sound could be caused by a fault. Does anyone have an idea how to get rid of the knocking, or where the cause might lie? Best regards icon_question.gif
Translated on 17-08-2026, 19:40.
Post08-01-2004, 13:51    Subject: Volvo V70: Loud Engine Knocking - What to Do? Quote
I would like to check (or have checked) the ESP timing.
Translated on 17-08-2026, 19:41.
Markus H.
Post08-01-2004, 18:00    Subject: Volvo V70: Loud Engine Knocking - What to Do? Quote
What Bertil says is certainly worth considering.
From my own experience, I know that this doesn't necessarily have to manifest itself in terms of noise.
But:
Has the Volvo become 'louder' recently?
If that's not the case, it could be due to different insulation, even though the engine is the same model ('AEL').
They are, after all, two completely different vehicles.
For example, the Audi C4 has a full enclosure.
P.S.: By the way, does the Volvo actually have a transverse engine?
Translated on 17-08-2026, 19:42.
olli
Karma: +46 / -0   Thank you, like it!
Post09-01-2004, 1:20    Subject: Volvo V70: Loud Engine Knocking - What to Do? Quote
Hi there,
The AEL (Active Emission Control) system is significantly louder in the Volvo compared to the Audi, primarily due to its transverse installation, reduced space, and less insulation.
"Tapping" doesn't necessarily always have to be a matter of engine adjustment. In the case of a 5-cylinder engine, the plunger for the vacuum pump often rattles, which can sound like tapping or rattling lifters to the untrained ear.
You can then replace the lifter rod. Usually, if the camshaft hasn't been damaged yet, the noise will go away for a while, but it will eventually return.
A new vacuum pump can only help to a limited extent.
Hydros are also a possibility, but those can be tested relatively easily.
What is the machine's mileage?
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 17-08-2026, 19:44.
D.
Post09-01-2004, 19:28    Subject: Volvo V70: Loud Engine Knocking - What to Do? Quote
Nozzles could also be an option.
Translated on 17-08-2026, 19:45.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loud TDi engine (81 kW) and excessive fuel consumption Diesel Engine Technology
No new posts Engine knocking, 140hp 2.0 TDI with DPF (BMM) Diesel Engine Technology
No new posts Rebuilt Engine Misfire: Causes & Fixes Diesel Engine Technology
No new posts Volvo/LT-Engine TIC Diesel Engine Technology
