Jan6K
10-01-2004, 11:37 Subject: |
@Dieselmartin: Exactly like it looks with the ARL, so it's the same for me, then there's no point in taking another photo.
The difference is simply that the pipe goes all the way down to the LLK.
Jan
1Z5 CFHF  / AHB H4D
Gremlin Guest
10-01-2004, 13:11 Subject: |
for completeness HERE my ALH..
See you, Gremlin
Julian Guest
10-01-2004, 13:15 Subject: |
for completeness' sake HERE my ALH..
It's already sprouting...
Gremlin Guest
10-01-2004, 13:26 Subject: |
There are 200km of A7 highway attached to it... you can come and clean it.
See you, Gremlin
Julian Guest
10-01-2004, 13:40 Subject: |
Hm, what could you offer me to make me come to you?
The last engine compartment I cleaned was that of my better half's Clio. It's still clean today - 5 months later - and is constantly praised by Laine and professionals for its cleanliness.
Gremlin Guest
10-01-2004, 16:15 Subject: |
Well, if he's just standing there broken or being carried around the city...
but now we're getting off-topic...
See you, Gremlin
WarLord Guest
10-01-2004, 16:46 Subject: |
@ the other 35i drivers:
(e.g., Warlord)
Is it like this at your place too?
Yep, that's exactly right.
He had a large coverage (similar to the AFN) starting from a certain model year.
Yep, mine has a cover. Just that it has 3 black letters on it. Like the one you linked in your later post. Regarding Lopez: Those who save like this will also starve their own children.
Should I maybe also do (engine compartment cleaning) sometime, but I don't really feel like it. It's just an optical defect.
Best regards, WarLord
10-01-2004, 18:24 Subject: |
@ Germlin
Ah, then that was your engine, which I had already linked
Profile PM Garage |
Julian Guest
11-01-2004, 9:29 Subject: |
Hehe, in itself. Here, however, there were other reasons, namely that the valve cover gasket was defective and the engine was quite oily (down to the oil pan, the previous owner must have had a very high oil consumption...).
If something like this is seen during the upcoming TÜV (vehicle inspection), there will be an entry in the report. And I want the mill to pass the TÜV inspection, because I've already put in way too much work...
Jan6K
11-01-2004, 14:13 Subject: |
Also, for completeness, here's the ASV on the 2001 Ibiza GP01. I didn't remove the bodywork, as it was too cold outside. "Eventually, when it's warmer, I'll replace the picture."
Jan
| Description: |
| File size: |
72.65 KB |
| Viewed: |
4707 times |
1Z5 CFHF  / AHB H4D
