Jürgen Guest
12-01-2004, 18:30 Subject: |
Okay, don't worry about your weight and just enjoy yourself.
not in the wrong place - IMO it should definitely be a GSD.
and not one of those things that you only attach to the trailing edge.
- is simply more comfortable and lighter in weight.
Well, there really isn't much of a difference!
Translated on 13-08-2026, 10:27.
12-01-2004, 18:40 Subject: |
Jürgen wrote: | Personally, I think it should definitely be a GSD.
Well, there really isn't much of a difference! |
Hi Jürgen,
Sure, a completely open vent is more aesthetically pleasing than just a small slit, but I also always think about the potential for malfunctions.
And in my opinion, the principle "the more primitive the mechanics, the more robust it is" still applies -> 1:1  . Gruß Ulf
Translated on 13-08-2026, 10:29.
Profile PM Garage |
WarLord Guest
12-01-2004, 19:24 Subject: |
@Bertil
Personally, I prefer to turn on the air conditioning when driving, even if it uses more fuel. That way, I know it will get cold.
Best regards, WarLord.
Translated on 13-08-2026, 10:30.
Bertil Profi-Schrauber
12-01-2004, 20:23 Subject: |
WarLord wrote: | @Bertil
"... Why are you telling me this? I have air conditioning and don't need a sunroof or sliding roof." Gruß Bertil
m3_bremse Guest
12-01-2004, 20:39 Subject: |
@Bertil
... Why are you telling me this? I have air conditioning... and don't need a sunroof or sliding roof.
... not due to weight reasons, right? }
Translated on 13-08-2026, 10:31.
Jürgen Guest
12-01-2004, 21:18 Subject: |
Hello Ulf,
The first Webasto unit lasted for 12 years without any problems.
Then I disposed of it by putting it in the car, because it only had very old approvals/certifications left.
'had in the documents. In addition, Webasto is, besides Rockwell, another...'
der Hauptlieferanten für ab Werk eingebaute GSD oder SSD. At the G4.
For example, a Webasto or a Rockwell unit can be installed from the factory.
In my opinion, the mechanical components of Webasto sunroofs are...
Excellent for retrofitting!
Furthermore, the mechanism is so simple that there's not much that can go wrong.
It's breaking down, but Webasto has replacement parts available!
(Sorry - I don't want to do any advertising for Webasto here!)
Translated on 13-08-2026, 10:33.
12-01-2004, 21:26 Subject: |
By the way, thank you very much for all the tips you've given so far (and perhaps still to come?).
With that, we will most likely be able to make the "right" decision  . Gruß Ulf
Translated on 13-08-2026, 10:34.
Profile PM Garage |
12-01-2004, 22:14 Subject: |
Hi Ulf,
If you're installing it yourself, please definitely create a photo documentation if possible.
While I don't plan to do that myself, I can imagine it might be useful for some people.
January. 1Z5 CFHF  / AHB H4D
Translated on 13-08-2026, 10:35.
WarLord Guest
13-01-2004, 13:33 Subject: |
@Bertil
Hmm, because you wrote something about increased consumption?
@Bertil
... not due to weight reasons, perhaps? }}
Hmm, I have both: air conditioning and a sunroof. *g*
Translated on 13-08-2026, 10:37.
