Do your car also have small dents on the side, caused by the careless neighbor? My garage removed some of these Aldiparkplatzbeulen for me - without repainting. The work was carried out by a third-party company at Audi. They are supposedly available throughout Germany. The cost is 99 euros for a body part, including a maximum of 5 small dents on undamaged paint. I can highly recommend this method. You can't see anything behind!
with the tennis ball, it only works if you do it from the inside.
arrives.
What Uwe probably means is pulling from the outside.
They stick a pen in the hole and then pull it out with
a device with a thread on it until the bump is gone.
Finally, the tool is removed and the area is polished.
Unfortunately, I wasn't there when my car was being repaired. Therefore, I didn't see them doing the work. The mechanic said that they were also pushing from the inside, and that the trim had to be removed. I don't believe it, as they only had about 2 hours to work on the car, and 99 euros is very little money for extensive repairs.
How does the tennis ball method work?
