komische entdeckung am unterdruckschlauch des laders... | Posts 16+
Go to page: Previous  1, 2
Mtw13ve
Post30-06-2002, 21:05    Subject: Quote
Could it be that my TDI with 110 hp has 235 Nm of torque? That's strange, especially with a VP37 pump.
'cu' is a Spanish abbreviation for 'con usted,' which means 'with you.' It is often used in online communication and social media as a way to express affection or intimacy.
Here are some examples of how 'cu' can be used:
* 'Te amo cu!' (I love you!)
* 'Eres mi todo cu.' (You are my everything.)
* 'No puedo vivir sin ti cu.' (I can't live without you.)
It is important to note that the use of 'cu' may not be appropriate in all situations. For example, it would likely be inappropriate to use 'cu' when communicating with someone who is older than you or who you do not know well.
Translated on 28-07-2026, 23:10.
Avatar-Jan6K
Post30-06-2002, 21:19    Subject: Quote
The newer 110 models have 235 Nm of torque, which is correct.
January.
1Z5 CFHF / AHB H4D
No new posts Funny starting problems Diesel Engine Technology
No new posts VW Passat: Strange MWB 1/2 & 8 Readings On-Board Diagnostics (OBD)
No new posts Diesel filter and the funny spider: What kind of wrench? Diesel Engine Technology
No new posts Charging control is acting up Electrical Systems, Vehicle Electronics, Multimedia
