Plug | Posts 16+
Go to page: Previous  1, 2
Harlyjoe
Post24-01-2004, 9:21    Subject: Plug Quote
Hi everyone, where can I actually get the plugs for the adapter?
Who makes these things?
Sincerely,
Sepp.
Post24-01-2004, 9:37    Subject: Re: Plug Quote
Harlyjoe wrote:
Hello everyone, where can one actually get the plugs for the adapter?
Sincerely,
Sepp
Hello Sepp,
You've identified the problem. That's why I also sell complete kits in the online store, which are guaranteed to work if assembled correctly. Or, I offer ready-made devices. And specifically, with an OBD2 connector. icon_cool.gif
Post24-01-2004, 10:50    Subject: Plug Quote
Tino Kossmann wrote:
What do K and L actually stand for, and what is the difference between K, K+L, K+K, and K+K+L (although it's probably only one of the last two variants that exists, right?)?
Hi Tino,
L is the "communication channel" through which the dialogue is initiated via VAGCOM using the adapter.
The actual data exchange only occurs via the K-line(s).
More recent models no longer have the L-Line, and the opening process for those also goes through K.
More details can be found here for reading.
Post24-01-2004, 23:16    Subject: Plug Quote
chrhelm wrote:
But I just noticed that the error crept in through the RS232 connector. icon_cry.gif
The following connections to the PC are required:
2 - RX
3 - TX
not the other way around...
I have sent the corrected circuit diagram to [email protected].
CH
Hi, I unfortunately didn't receive an email.
Harlyjoe
Post25-01-2004, 8:38    Subject: And where did you get the plugs? Quote
Who manufactures the plugs, Thyco...?
AMP?
Are there any order numbers?
Sincerely,
Sepp.
Post25-01-2004, 11:49    Subject: Plug Quote
Hi Sepp,
Was that a rhetorical question? I don't run my online shop just for fun... icon_twisted.gif
By the way, AMP offers pre-assembled cables (hello, just connectors and 16 wires) where I was quoted a special price of around 110 Euros per cable for purchases in quantities of 25. icon_cool.gif
I even specifically asked again to make sure they hadn't accidentally meant 110 euros for 25 cables...
Discussions about plugs should take place elsewhere, but not in this forum.
The kit, which is now offered in the shop, can be assembled and made functional in 30 minutes with a reasonable amount of skill, and it has the advantage that, unlike auction-based systems or circuits with only 1-2 transistors, it works with every laptop with an RS232 interface.
Right away, something good: HEX-USB.
And for the price of 1 1/2 tankfuls of gas, everything arrives nicely packaged in your living room. icon_exclaim.gif
And for those who don't have a soldering iron, the adapter is also available as a complete unit. It has been tested, is functional, comes with a 2-year warranty, and includes a CD with a shareware version of VAG-COM + English documentation. VAG-COM user manual + €10 voucher for activating the VAG-COM shareware version to the full version.
The pre-assembled device also comes with English instructions. VAG-COM full version, available in a more affordable bundle.
joergs
Post25-01-2004, 12:24    Subject: Plug Quote
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Minimal laptop for VAGCOM? Diesel Engine Technology
No new posts VAGCOM Adapter: The Essential Guide Diesel Engine Technology
No new posts VAGCOM USB Adapter: Professional Edition Diesel Engine Technology
No new posts VAGCOM Adapter: Power Consumption & Requirements Diesel Engine Technology
