Disable windshield wipers!!
Animalking
Post02-07-2002, 8:19    Subject: Disable windshield wipers!! Quote
Since I have repurposed my windshield wiper system icon_biggrin.gif into a charge air cooler sprinkler system, I would now like to disable my windshield wipers. The problem is that when the windshield wiper system is activated, the windshield wipers also start running. I want it so that only when the windshield wiper lever is pulled backward, ONLY the windshield wiper system functions, and the windshield wipers do not start running!!! Can anyone help me? I have a Golf IV!
THANK YOU VERY MUCH.
Stukov
Post02-07-2002, 9:32    Subject: Disable windshield wipers!! Quote
Maybe you already know this, but I'm writing it here anyway.
According to German road traffic regulations (StVZO), a fully functional windshield washer system is mandatory, and a vehicle without one is not approved for road use.
Exaggerated example:
Your windshield is getting dirty due to a lot of dust/insects, you can't clean it anymore, and you end up having an accident...
We're all familiar with that feeling when you're too lazy to refill the water.
Ingo
Post02-07-2002, 9:33    Subject: Disable windshield wipers!! Quote
I would spontaneously suggest checking which other devices are connected to the same fuse, as the windshield wiper is likely not on its own circuit. If it's only for a short time, maybe just remove the corresponding fuse.
Or maybe take a look at the windshield wiper motor; there's probably a connector there that you can simply unplug. However, this will require removing several plastic trim pieces.
Or you could unscrew the wiper arms, as there's only one screw per wiper arm.
That's all I can think of.
Ingo
Post02-07-2002, 9:35    Subject: Disable windshield wipers!! Quote
Stukov is right, we shouldn't overlook that!
Ingo
Animalking
Post02-07-2002, 9:42    Subject: Disable windshield wipers!! Quote
Thanks for the answers, but I still need the wipers to work because I'm stuck if it rains. What I want is to disable the wipers *only* when using the cleaning system, not completely! Nevertheless, THANK YOU icon_wink.gif
Post02-07-2002, 10:16    Subject: Disable windshield wipers!! Quote
The simplest way would probably be to build a simple button into a blank plug for the center console, which, when pressed, would supply power to the windshield wiper motor.
A luxury version would involve using a temperature sensor on the coolant reservoir or utilizing the charge air temperature sensor to activate the windshield washer pump motor. Then, a solenoid valve could also be used to switch the path of the spray water, directing it either between the windshield and the radiator or elsewhere.
A time limit might be useful, so that the windshield washer motor doesn't melt if someone drives at full speed for 10 km on the highway. icon_razz.gif
Feedback on the status of the windshield washer fluid cooling system is provided via an LED indicator in the center console plug. When the windshield wiper lever is activated, the system automatically switches back to the normal mode (spraying onto the windshield).
My suggestion for the simple version:
The button activates a solenoid valve that switches the windshield washer fluid from the windshield to the radiator, while simultaneously activating the windshield washer pump motor.
Animalking
Post02-07-2002, 10:23    Subject: Disable windshield wipers!! Quote
Thank you very much. Now, if you could tell me how to activate the water pump separately, I would be very grateful! icon_smile.gif
Post02-07-2002, 10:50    Subject: Disable windshield wipers!! Quote
Animalking wrote:
THANK YOU very much. If you could also tell me how to activate the water pump separately, I would be very grateful! icon_smile.gif
Well, it shouldn't fail because of that icon_wink.gif.
"On my water pump, there are 2 wires, and the decision of whether to spray from the front or the back seems to be determined by the direction of the motor's rotation (?)." Please correct me if anyone knows more.
Get a 2X relay that you can use to switch the two connection wires to the motor between the 'normal' and protected +12V, and ground.
You supply power to the relay coil by, for example, applying a protected +12V to the coil via a button in the center console. You can connect the other end of the coil to the ground terminal of the motor.
You can connect the solenoid valve that switches the water hose between the disc and the intercooler in the same way.
If you press your button, the following happens:
The solenoid coil is energized and switches the water hose from the disc to the windshield washer system. The relay coil is energized and switches the connections of the windshield washer motor from 'normal' to +12V and ground -> water flows.
If you activate the windshield wipers, everything functions as it should.
Animalking
Post02-07-2002, 14:46    Subject: Disable windshield wipers!! Quote
Okay, I understand. I have one more question: Does anyone happen to know how much electricity a water pump uses, so I can figure out what size fuse I need?
Uwe
Post02-07-2002, 16:28    Subject: Disable windshield wipers!! Quote
Hi!
Another option would be to tap into the windshield washer line for the rear window and disable the rear wiper. Then all the important functions are preserved, and it's easier to install.
What is the effect of liquid-cooled microprocessors that use water for cooling?
Uwe
No new posts Windshield Wiper Regeneration General Tips
No new posts Avoid squeaking windshield wipers at the front General Tips
No new posts Windshield wipers needed!!!! Transmission, Chassis, Body & Interior
No new posts Wiper blades on Golf 4 are malfunctioning Electrical Systems, Vehicle Electronics, Multimedia
No new posts Windshield Wiper Motor Malfunction Diesel Engine Technology
No new posts Wiper Problems: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
