Oil Dipstick Tube: Stability & Reliability
SeatLeon
Post17-12-2003, 9:57    Subject: Oil Dipstick Tube: Stability & Reliability Quote
'Does anyone have any idea how stable the dipstick tube (plastic) itself and its attachment to the oil pan are? The reason I ask is this: I wanted to check my oil level, so I removed the sender dipstick and tried to insert the original one. However, it only went in with a relatively large amount of force. I have to say that the original dipstick has always been quite difficult to insert and remove. I'm always afraid that I might rip the tube out of the oil pan. Is this fear justified, or is this part extremely robustly designed? This is for an ALH engine. But it should be the same for every 1.9 TDI, right?'
Translated on 23-08-2026, 14:17.
mersente
Post08-02-2004, 21:37    Subject: Oil Dipstick Tube: Stability & Reliability Quote
Hello, please sand down the three rings a little bit smaller; the ones that are on the dipstick. It's best to use 120 grit sandpaper. Then it will be easier to move, otherwise you won't break the tube. icon_smile.gif
Translated on 23-08-2026, 14:18.
Achim
Post09-02-2004, 9:33    Subject: Oil Dipstick Tube: Stability & Reliability Quote
'Hi,'
@SeatLeon,
The orange plastic tube is attached to a steel pipe that is connected to the engine block/oil pan.
The plastic pipe is attached, but with some force, it can be pulled off the steel pipe.
You won't be able to pull that steel pipe out of the engine block.
Translated on 23-08-2026, 14:19.
No new posts Ölspritzrohr in der Ölwanne! Diesel Engine Technology
No new posts Ölwanne ausbauen Diesel Engine Technology
No new posts Oil Pan Gasket 1Z Diesel Engine Technology
No new posts A4 8E Oil Pan Removal: Guide & Instructions Diesel Engine Technology
