Does the fuel injection pump fit?
dennis
Post10-02-2004, 13:53    Subject: Does the fuel injection pump fit? Quote
Hello, I've used the search function, but unfortunately, I haven't found anything. So, here's my question: Can I install the fuel injection pump from a 90 HP Passat TDI (with AHH engine code) into my 110 HP Passat TDI (with AFN engine code)? Are there any differences in the structure, or should I expect a performance decrease? Or does it simply work because it's the same [thing]?
Greetings from the Harz region.
Post10-02-2004, 14:38    Subject: Does the fuel injection pump fit? Quote
I have a bad feeling that this question will lead to the same problems as here.
Okay, first of all:
Do you have any ET or Bosch part numbers for the pumps?
That would significantly help the situation.
Generally, it might be possible to get this combination working, but I wouldn't bet on it.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Does the transmission fit the ALH? Diesel Engine Technology
No new posts Passt der 1Z aus Golf 3 in den Audi 80 B4? Diesel Engine Technology
No new posts Probleme mit Passt 96kW TDI Diesel Engine Technology
No new posts ESP vom GolfIV an AFN (bj.97) -> Passt Halter vom AHH ? Diesel Engine Technology
