Engine cranks but won't start?
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
Diesel Engine Technology
View previous topic
View next topic
Author
Message
Daniel_Diesel
13-02-2004, 6:30
Subject: Engine cranks but won't start?
Quote
Hello.
Okay, here's a really silly question.
What can I do if my car won't start?
Okay, I just mean letting the starter motor turn the engine over.
Because I need to remove the air from the oil supply line to the turbocharger before I can run the new turbocharger with the engine.
Is there a fuse or plug that can be removed?
If so, where??
And if possible, without any strange error codes appearing in the error memory again?
Passat 3BG, 1.9 PD AVF, 2001.
Translated on 20-10-2026, 18:50.
dieter
Quote
Hi there,
Remove the famous Relais 109. Then it won't start, and the control unit won't be able to store anything either.
greetings
dieter
Translated on 20-10-2026, 18:51.
Profile
PM
PowerSound3L
13-02-2004, 8:55
Quote
hi,
Does a PM motor still have the 109 relay?
I don't think so.
I see only one way to disconnect the connector from the PD elements and then clear the error memory.
greetings
Translated on 20-10-2026, 18:52.
13-02-2004, 15:06
Quote
PowerSound3L wrote:
hi,
I don't think so.
According to the documents I've gathered so far for my new PD-Polo, at least the relay 109 is still present (I'm still waiting for the car...).
Translated on 20-10-2026, 18:53.
Profile
PM
Garage
Manuel Thomas
13-02-2004, 15:43
Quote
You can start the engine normally and then let it run for about 30 seconds at idle.
You've already filled the oil reservoir with oil, which is enough until the oil pressure builds up!
They don't break that easily!
Manuel.
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Lupo Door Problems: 6X1 MJ 2002 Repair Guide
AJM Engine: Rattling, Power Loss, Black Smoke
Power loss without soot
How to crank a TDI AHU engine without starting it.
AAZ Engine: Get it registered for your VW T3
VTG Rods: How to Rotate Them Properly
How to make longer VTG rods.
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.045s
