Intake air temperature?
Animalking
Post03-07-2002, 21:14    Subject: Intake air temperature? Quote
Hi everyone, I recently got a VAG COM diagnostic tool, and I'd like to know which channel I can use to measure the intake air temperature. Also, what does the display 'NM' mean? Does it represent Newton Meters (Nm), which are the values acting on the wheel, or something else?
I have a VW Golf IV with an ATD engine.
Post04-07-2002, 8:38    Subject: Intake air temperature? Quote
For 4-cylinder engines that are not PD TDI, the charge air temperature is located in measurement block 7 of the engine control unit.
1. Fuel temperature sensor in the fuel injection pump.
2. Value: N/A
3. Value: Intake air temperature / Charge air temperature.
4. Cooling water temperature value.
You should have been able to figure out that the diagnostic tool cannot measure Nm at the wheel, because there is no corresponding measuring device present icon_wink.gif.
If something like that is displayed, it's a value stored in the engine control unit that has nothing to do with reality.
Animalking
Post04-07-2002, 9:33    Subject: Intake air temperature? Quote
Okay, good, thanks. I was already thinking that about the NM (Newton-meters) because you need a dynamometer to measure that!
Hmm, I'm also having a problem where VAG-COM can't find a label file for my TDI PD ATD. Could that be because the 100 HP variant is a fairly common model?
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts TDI Coolant Temp Sensor for Audi Convertible Upload
No new posts Diesel Temperature & Intake Air Temp Under Load Diesel Engine Technology
No new posts Charging Air Temp/Pressure Sensor: Do You Have It? On-Board Diagnostics (OBD)
No new posts ASZ Fabia RS 131PD Intercooler Temperature Issue Log File Upload
