LMM and Cat Issues: Troubleshooting Guide
claus49
Post30-08-2003, 23:59    Subject: LMM and Cat Issues: Troubleshooting Guide Quote
"For the past three days, my Passat TDI 3B (5), manufactured in 7/97, with 92,000 km and 90 hp (AHU engine), hasn't been accelerating properly. It takes a long time to reach just 140 km/h on a flat surface. Before this, for a few weeks, it has been making rattling noises from the front part of the exhaust system. Yesterday, I tried the following:"
1. The LMM (Pierburg) was sprayed multiple times with brake cleaner, with no change in result. The grilles also make it difficult to spray accurately.
2. LMM connector disconnected, result: no change.
"Short-circuiting the LMM (lambda measurement module) connector with a diode, without modifying the EGR (exhaust gas recirculation) system, resulted in the engine running very poorly. It exhibited rough running, misfires, and excessive smoke production, particularly under partial load."
1. Question: Does this clearly identify the LMM as a source of error?
2. Question: Can the Pierburg mass airflow sensor (MAF sensor) be easily replaced with a Bosch MAF sensor? The connector probably won't fit, right? (Bosch MAF sensors are available on eBay, but I haven't found any Pierburg ones yet).
The rattling sound from the exhaust system is likely coming from a faulty catalytic converter. Since it's probably deteriorating further, it would be advisable to replace it. There's a possibility that the exhaust flow is already restricted. However, the fact that the car ran relatively well with a diode bridge connected to the mass airflow sensor (MAF) connector might argue against this. But if the catalytic converter isn't completely blocked now, it could become a problem at any time.
Now, my problem is:
In which direction will this data center be expanded, upwards or downwards?
Which other components should be disassembled beforehand?
It looks like the rest of the exhaust system will need to be removed.
It looks incredibly cramped up there. I have no idea how to loosen those four nuts at the top without disassembling other components (and which ones, at that). Okay, two of the nuts are easily accessible, but the other two...
Unfortunately, there is no detailed manual available for this vehicle, and the "How it's done" guide by Etzold doesn't offer any information either. I haven't found anything else yet.
What was my old Passat (model year 1981, 54 hp) so easy to repair icon_wink.gif.
I would appreciate it if you could give me some tips and advice.
Have a lovely Sunday and a good start to the week.
Claus.
Translated on 12-10-2026, 21:34.
mersente
Post18-02-2004, 21:13    Subject: LMM and Cat Issues: Troubleshooting Guide Quote
Hello, based on the test you performed, your LMM is clearly defective.
You get the cat out from up there.
Translated on 12-10-2026, 21:38.
Max d. Ä.
Post18-02-2004, 21:21    Subject: LMM and Cat Issues: Troubleshooting Guide Quote
You can get the Pierburg mass airflow sensor (MAF sensor) from VW as a replacement part for around €80. I would definitely have it replaced.
Max.
claus49
Post18-02-2004, 22:23    Subject: Final Report: Key Findings and Conclusions Quote
Since I received a few more answers to my question, I would like to provide a final report to the forum.
Since the cause of the error was unclear, I contacted A*U in desperation. Although this company, like others, sometimes receives negative reviews, I was surprised by the helpfulness of the team in Darmstadt. I read the error codes: the mass airflow sensor (MAF) was defective. They provided me with a MAF sensor for testing purposes, but the result was no change. Two days later, we removed the catalytic converter, which was loose and rattling inside the housing. Of course, it was blocking the exhaust pipe, and it had really become embedded. We replaced the catalytic converter, and everything was okay. I cleared the error codes, took it for a test drive, and read the codes again, and everything was okay.
As far as I recall, the cost included the catalytic converter itself and its installation, and it was around 390 euros.
There's nothing to complain about.
It's unfortunate that the catalytic converter only had a lifespan of approximately 90,000 km. Its mounting should have lasted longer.
Best regards, Claus.
Translated on 12-10-2026, 21:40.
Max d. Ä.
Post19-02-2004, 7:03    Subject: LMM and Cat Issues: Troubleshooting Guide Quote
Thank you for the feedback!
Bye.
Max.
Translated on 12-10-2026, 21:41.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASU Issues: Troubleshooting and Solutions Diesel Engine Technology
No new posts 2.5 TDI AAT Problems: Common Issues & Fixes Diesel Engine Technology
No new posts ABS Problems: Causes and Solutions On-Board Diagnostics (OBD)
No new posts ALE: Troubleshooting GRA Issues in MKB Diesel Engine Technology
