TDI Graph: Analyze & Optimize Engine Timing
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
dicc
Post20-02-2004, 23:40    Subject: TDI Graph: Analyze & Optimize Engine Timing Quote
How do you properly check the timing? When I test it at idle, my values are slightly below the lower limit. And when I give it some throttle, they drop even further!
DICC
Translated on 18-08-2026, 19:26.
Post21-02-2004, 14:59    Subject: TDI Graph: Analyze & Optimize Engine Timing Quote
Do not accelerate. The default settings mode must be enabled (I'm not sure if the timing checker also works in a non-default settings mode, and it's extremely cold outside).
Otherwise:
 TDI Spritzbeginneinstellung mit TDI-Graph
 File size:  16.9 KB
 Viewed:  2366 times
Translated on 18-08-2026, 19:27.
No new posts Fehlbedienung TDI Timing Checker On-Board Diagnostics (OBD)
No new posts Understanding Injection Start, TDI Timing Checker Diesel Engine Technology
No new posts TDI-Graph error message "Timing to advanced" On-Board Diagnostics (OBD)
No new posts TDI Graph and AKN? Diesel Engine Technology
