Immobilizer for VW Passat Highline, 11/97, 110 HP
Vacancy
Post25-02-2004, 9:08    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Hi everyone!
Looking for a wiring diagram for the web-based immobilizer system in a Volkswagen Passat.
What happens if I disable part of the immobilizer system in my Passat?
which connects to the ignition switch?
MFG VACANCY
Translated on 14-07-2026, 20:35.
joergs
Post25-02-2004, 9:15    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Take a look at this.
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 14-07-2026, 20:36.
Vacancy
Post25-02-2004, 9:31    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Thank you for the information, but unfortunately, it doesn't really help me.
Does the device throw an error if I disconnect (interrupt) the reading coil?
PrivatBereich
Post25-02-2004, 9:59    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Without the reading head, the WFS (likely referring to a specific system or device) will not function and will lock the MSG (likely another system or component). It is therefore impossible to start it in this state.
After reconnecting the coil, everything should work again. Ideally, the error should be stored as soon as you try to start it. However, it seems to disappear after about 50 starts.
Could you please tell me why you want to know this/what you're trying to achieve by disconnecting the coil (permanently or temporarily)? Perhaps then someone will be able to guess what you're aiming for and give you the appropriate answer.
Private.
Translated on 14-07-2026, 20:37.
Vacancy
Post25-02-2004, 10:29    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Ich möchte mir zusätzlich Testweise einen Microcontroller einbauen (Atmel AT4433) der mir ein zusätzliches Sicherheitssystem übernimmt dazu kommt noch ein Peilsender gibts dann kostenlos die Bauanleitung wenn ich fertig bin ! Ich habe noch einiges an Arbeit vor mir es ist allerdings dass das mir der Mikrokontroller (theoretisch wenn möglich) irgendwie das stg so sperren muss sodass man das auto nicht mehr in Gang setzen kann . And the alarm system can be triggered. Such a system already exists, but it costs a whopping €550. Why buy it when I can build it myself?
Manufacturing Vacancy.
Translated on 14-07-2026, 20:38.
Post25-02-2004, 10:37    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Hello Mr. Ferien,
Here's a suggestion: If someone wants to steal the box, they'll either come with a tow truck or with an engine control unit for your car.
So, if you only block the already blocked WFS (Web Feature Service), a "swap engine control unit" might not be very interested in that.
It might be better to hide a solenoid valve for fuel supply/cutoff or short-circuit the signal from the throttle position sensor in the ESP system, or something else that isn't easily bypassed like a "standard" security measure.
Translated on 14-07-2026, 20:39.
Vacancy
Post25-02-2004, 10:46    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Steering angle sensor signal in the ESC
Can you please explain to me exactly what you mean and how I should do that?
You are right about the immobilizer; if he were to modify the control unit!
But before that happens, the car will be long gone *gggg*.
MFG VACANCY
Translated on 14-07-2026, 20:40.
Post25-02-2004, 14:22    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Vacancy wrote:
Lane keeping assist signal in the ESC
MFG VACANCY
However, a hidden solenoid valve/relay or similar device would be more versatile...
Translated on 14-07-2026, 20:42.
Vacancy
Post26-02-2004, 7:58    Subject: Immobilizer for VW Passat Highline, 11/97, 110 HP Quote
Actually, it should be quite simple to achieve this using a solenoid valve by blocking the fuel supply to the injection pump or disabling the starter motor with a corresponding relay.
If I block the starter, I have the problem that I need a relay that can handle the current.
If I block the diesel supply using a magnetic relay, the engine won't run and will no longer function!
Translated on 14-07-2026, 20:43.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Suche Codierung VW Passat Wegfahrsperre On-Board Diagnostics (OBD)
No new posts A6 2.5 TDI AEL Immobilizer On-Board Diagnostics (OBD)
No new posts Car Alarm System: AI & Immobilizer for Audi A6 4B Diesel Engine Technology
No new posts Car Alarm Hacked: How to Prevent It Diesel Engine Technology
