Clicking Relay Noise: Causes & Fixes
Roadagain
Post26-02-2004, 18:01    Subject: Clicking Relay Noise: Causes & Fixes Quote
Okay, I have a Passat with a 1Z engine.
There is a relay with vacuum connections on the fuel injection system. It is constantly clicking even when the engine is running, regardless of whether the engine is warm or cold.
Otherwise, it doesn't show any other issues, except that it has trouble starting below -1°C.
(but I was actually thinking more about the spark plugs).
So far, it hasn't done that, and it doesn't sound like it's supposed to.
What is this part for?
Is this a known issue? What could be the cause?
Greetings.
Translated on 18-09-2026, 8:56.
Post26-02-2004, 18:07    Subject: Clicking Relay Noise: Causes & Fixes Quote
Hello.
Here's the information about the N75 one last time - otherwise, please search for it yourself!
This is NOT an underpressure valve, but an overpressure valve.
It ends with 028 906 283 F or N75, or "magnetic valve for boost pressure limitation."
At VW, you can get a new one for 30 euros.
There are reports that the new [item] either doesn't rattle at all, or continues to rattle in the same way.
Some engine control units activate the device even without the engine running (i.e., just with the ignition on), while others leave it inactive when the engine is not running.
If your boost pressure curves (VAGCOM) are okay, then a replacement is just a cosmetic fix.
Since absolutely NO boost pressure is built up when starting, this has NOTHING to do with starting problems.
Mine also rattles too and now needs quite some time to start working.
For the Volkswagen Golf 3.
http://people.freenet.de/golf-schrauber/Magnetventil.jpg
Regarding the Passat 3A.
http://mitglied.lycos.de/matcher76/Bilder/EUV%20vor.jpg
Translated on 18-09-2026, 8:58.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Whistling at idle Diesel Engine Technology
No new posts Differential Pressure Readings at Idle Diesel Engine Technology
No new posts AJM Idle Speed Instability: Causes & Fixes Diesel Engine Technology
No new posts Idling fuel consumption, Polo 86c AAV Gasoline Engine Technology
