I performed an actuator diagnosis on my 1Z this weekend.
(028 906 021 AF)
The following oddities have come to my attention:
- During the AGR test, the membrane slowly extends and then quickly retracts with a noticeable "pop" sound.
- The engine noise is obviously changing significantly due to intake resonance.
- He's trying to do a climate diagnosis even though I don't have one.
- It does NOT check the N75 valve (boost pressure) or the glow plug heating system.
Did I make a mistake – for example, not restarting immediately after the N109 (stopper)?
I would have been particularly interested in the tests that were not conducted.
During the EGR test, the membrane slowly extends and then quickly RETRACTS (I've seen it extend slowly, and the retraction is even audible);
Hi Martin,
"In my opinion, this is due to the different internal flow cross-sections of the EGR solenoid valve. Only a capillary is opened for the vacuum pressure, while a larger tube is used for the positive pressure."
My mechanic also checked the charging valve and the GSH -> I have no idea why it's not working for you .
Hi Martin,
When performing a climate control system check using actuator diagnostics, various prerequisites must be met, such as the outside temperature, inside temperature, blower speed, etc. Please refer to the repair manual (which also specifies the sequence) and your voicemail for more details.
