AGR Fehlerdiagnose - brauche Rat ! | Posts 16+
Go to page: Previous  1, 2
MikeL
Post26-02-2004, 12:57    Subject: Quote
Hello, if your car starts to produce black smoke when it's running at partial load, then it's not getting enough air.
If the EGR valve is closed, it won't produce soot, as you mentioned.
It's quite possible, as Jan wrote, that a leak in the boost pressure system is the cause.
A clogged air filter could also be a possible cause.
Perhaps you could post a picture of the turbocharger that is installed in your car.
It should be a Garrett turbocharger. I don't think there's a hole in the boost pressure area; if there were, the boost pressure sensor would likely trigger an error message, and you would notice a decrease in performance.
I suspect it's more likely a problem with the EGR valve control. BMW wants to check that now. The parameters in the engine control unit are adjustable, similar to how it works with VAG-COM on Audi/VW vehicles.
Translated on 11-08-2026, 3:18.
Post26-02-2004, 13:35    Subject: Quote
@dieselmartinViewing profile: dieselmartin
dieselmartin wrote:
Here's another one with an electric parking brake (with the ribs at the back).
The reproduction of copyrighted images requires the permission of the copyright holder! icon_wink.gif ...
Did you ask the creator of this image?
@MikeL
How about you, what's your experience with LMM?
BMW is experiencing similar problems with the mass airflow sensor (MAF) as Volkswagen. When the MAF provides incorrect data intermittently, it can cause excessive soot emissions.
I'm starting to doubt that your problem is primarily related to the EGR valve.
Translated on 11-08-2026, 3:20.
Post26-02-2004, 16:18    Subject: Quote
@ Bertil
Well, that's a matter of "public interest," so I don't need to ask any further questions!
Translated on 11-08-2026, 3:21.
MikeL
Post26-02-2004, 17:31    Subject: Quote
@MikeL
I'm slowly starting to not believe that your problem is primarily related to the EGR valve.
The mass airflow sensor (LMM) has already been replaced and is working correctly. Now, BMW has made another change to a parameter in the software related to the EGR valve, which was apparently not set to the correct value. I need to test it again now.
Translated on 11-08-2026, 3:22.
Post26-02-2004, 18:26    Subject: Quote
dieselmartin wrote:
@ Bertil
@MikeL
MikeL wrote:
The mass airflow sensor has already been replaced and is okay. BMW has now made another change to an AGR parameter in the software, which was apparently not set to the correct value. Now I need to test it again first.
Okay, it was just an idea.
Translated on 11-08-2026, 3:24.
MikeL
Post01-03-2004, 10:35    Subject: Problem Solved: Quick & Easy Solutions Quote
The problem has been resolved. The workshop changed the EGR control parameter using the diagnostic interface (DIS) to a different, lower value. Since then, there's been no more black smoke, and the car runs better. Thank you again for your suggestions.
The VW/Audi group has it better here because you can at least intervene yourself using tools like VAG-COM, while BMW owners are always dependent on the workshop. icon_wink.gif
Mike.
Translated on 11-08-2026, 3:26.
No new posts Lupo 3L: No Gears / Troubleshooting Transmission, Chassis, Body & Interior
No new posts What do I need? On-Board Diagnostics (OBD)
No new posts Which version do I need? On-Board Diagnostics (OBD)
No new posts Control Unit Help: Troubleshooting & Repair On-Board Diagnostics (OBD)
