Passat 3B: Shifter Knob Wobbles During Gear Changes
WarLord
Post14-03-2004, 21:05    Subject: Passat 3B: Shifter Knob Wobbles During Gear Changes Quote
... The gearbox is imprecise, has a poor biting point, and feels cheap. My old Passat is no comparison; it shifted smoothly, was precise, and had a nice feel. Is there anything that can be done about this (e.g., different shift cables)? It's the 6-speed gearbox (GKB grade unknown) on an ATJ engine.
I also have a problem where the second and third gears make a grinding noise when the transmission is cold, and even when it's warm, the third gear still feels a bit stiff to engage. However, I'm sure this will be resolved by using a different type of transmission oil.
Best regards, WarLord.
Translated on 30-07-2026, 15:49.
Post15-03-2004, 18:28    Subject: Passat 3B: Wobbly Gear Shift Knob - Fix It! Quote
WarLord wrote:
... The gearbox is imprecise, has a poor biting point, and feels cheap. My old Passat is no comparison; it shifted smoothly, was precise, and had beautiful damping. . .
Have you tried adjusting or replacing the shift linkage or cable(s)?
The position of the gear lever felt too far back to me overall, and I wanted to correct it by adjusting the cable.
Of course, I initially selected the wrong gear for left-right shifting... in short: after just two adjustment attempts, some gears simply wouldn't engage at all, and the rest were extremely jerky - even though the FSM gearbox usually shifts perfectly well.
I managed to do it again.
Of course, it will take a bit longer without a gauge, but I think it might be worth trying for you as well.
Translated on 30-07-2026, 15:51.
WarLord
Post15-03-2004, 23:14    Subject: Passat 3B: Shifter Knob Wobbles During Gear Changes Quote
The gears are engaging well (including R, 1, 2, 5, and 6), but the shifting itself doesn't feel good. I also need to replace the shift knob; the one from the 3B isn't great (it's thick at the top, tapering down for about 2 cm, then suddenly becomes thinner).
Translated on 30-07-2026, 15:53.
No new posts 1.9 PD-TDI ATD engine: hard shifting/jerking under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0044 AMF, Creaking noise during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, noises during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C Variant, 1.4 TSI - Noises during load changes Transmission, Chassis, Body & Interior
No new posts Passat 3c kratzendes Geräusch bei Kurve+ Lastwechsel Transmission, Chassis, Body & Interior
No new posts Steering Wheel Problems: Wobbles & Pulls Transmission, Chassis, Body & Interior
No new posts Ibiza 6L Driver Seat Wobbles - Fix It! Transmission, Chassis, Body & Interior
