Wurstblinker Guest
11-03-2004, 13:20 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
Hi there,
about the car:
Audi A4 8E Avant, 96kW TDI.
Oct. 2001
5 gears.
45,000 km
The following problem:
When driving in third gear and downshifting to second using engine braking, the car makes a very loud 'clack-clack' noise. It sounds very dull, but also quite harsh.
However, even when using reverse gear and releasing the clutch, this noise is still present, although it's quieter because the load is lower.
In my opinion, it's the engine or transmission mount(s).
Or something else entirely?
Who knows this problem?
What is the cost of a storage unit?
Sure, here's the translation:
'Goodwill?'
As soon as Audi opens the hood, they want money, is that normal?
Thank you all.
Sausage blinkers.
Translated on 19-07-2026, 13:03.
Wurstblinker Guest
16-03-2004, 12:22 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
It's the gearbox bearing! It's completely worn out.
If we're unlucky, the engine mounts might also be damaged, and in that case, the bumper needs to be removed for access.
Is it complicated to put the bumper into service position?
Thank you and...
Translated on 19-07-2026, 13:06.
bloeckler
16-03-2004, 17:30 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
Can anyone estimate the approximate cost of the replacement?
Wurstblinker Guest
16-03-2004, 18:39 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
I'm going to a friend's workshop tomorrow, and we're going to replace the transmission mount first.
That thing costs 60 euros.
Then we'll see if it's gone!
Translated on 19-07-2026, 13:07.
bloeckler
16-03-2004, 21:19 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
Sure, I can translate the text for you and then briefly explain how complex the exchange process is and what to keep in mind.
Here's the translation:
"Perhaps you could explain afterwards how complicated the exchange was and what one needs to consider when doing it."
Wurstblinker Guest
16-03-2004, 21:51 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
Sure, no problem.
Do you have the same problem? How many kilometers are on it?
Translated on 19-07-2026, 13:08.
bloeckler
Wurstblinker Guest
18-03-2004, 22:53 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
Okay,
Everything worked out!
The change took about half an hour. We had the car on a lift, and to remove the bearing, we supported the transmission on the ground and lowered the car slightly. This freed the bearing, allowing it to be removed.
The noises are gone, and the old bearing is definitely at the end of its life. However, I can't understand how this could happen after only 45,000 kilometers. 'Made in Germany' means something different to me!
Sausage blinkers.
Translated on 19-07-2026, 13:09.
bloeckler
19-03-2004, 16:33 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
So, no excessive effort involved? Did you use the original part or a replacement from a supplier?
Translated on 19-07-2026, 13:10.
Wurstblinker Guest
19-03-2004, 16:37 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
The effort required is a joke.
We used an original part because there was nothing available as an accessory. But I think €60 is still a reasonable price!
bloeckler
19-03-2004, 16:41 Subject: Popping noises during load changes on a VW Golf A48E 1.9 TDI |
"How exactly did you verify whether the component was present in stock or had already been sold out? Was it only possible to determine this by physically removing the item?"
Translated on 19-07-2026, 13:11.
