003 and 008 Log from ASV inside
Post19-03-2004, 0:01    Subject: 003 and 008 Log from ASV inside Quote
I just had a Seat Ibiza 6L ASV in my hands.
The part naturally had to be immediately re-populated with data icon_smile.gif
Here are 2 logs, in case anyone is interested.
http://www.luxus-wg.de/~martin/auto_bilder/2004_03_18_laurent.zip
Jan6K
Avatar-Jan6K
Post19-03-2004, 8:45    Subject: 003 and 008 Log from ASV inside Quote
The ASV (81 KW) is only fitted in the 6K engine (also known as GP01) from 1999 onwards, while the 6L is the subsequent model built from 2002 onwards, and exclusively uses PD-TDI engines, namely the ATD (74 KW) and ASZ (96KW), as well as the 1.4 TDI.
So, your log is either from the 6K / ASV or 6L / ASZ...
Jan
1Z5 CFHF / AHB H4D
Post19-03-2004, 9:28    Subject: 003 and 008 Log from ASV inside Quote
Oops, sorry, I reversed the names of the {CAR}.
It was a 110 PS VP - so ASV.
Thank you.
Definitely, that thing worked like a charm.
On my DZR home track (unfortunately slightly uphill) with 3 people, using a 7.6 and a 6.6.
The logs are without box.
Also, it was also nice to see:
- LL dosage without box 4.4 mg/H - with box 1.2 mg/H
- Group 000 basic settings have NOT changed the noise - so the pump is already set to run late?
*ROAR I want a VTG too*
Gremlin
Post19-03-2004, 11:24    Subject: 003 and 008 Log from ASV inside Quote
regarding the inverted LL fuel injection volume, I'm more inclined to think it's a completely stupid box...
See you, Gremlin
Jan6K
Avatar-Jan6K
Post19-03-2004, 15:56    Subject: 003 and 008 Log from ASV inside Quote
I'm not very familiar with Spanish.
But I... that's exactly the same car as mine.
Can I confirm.
During my measurements in the summer of 2002 (I need to repeat them to see any changes), I achieved an average DRZ time of around 6.25, measured with VAGCOM and interpolation, and without any tuning.
Jan
1Z5 CFHF / AHB H4D
WarLord
Post19-03-2004, 16:21    Subject: 003 and 008 Log from ASV inside Quote
I love this howling. *g*
Best regards, WarLord
BlauBaer
Post19-03-2004, 19:42    Subject: 003 and 008 Log from ASV inside Quote
hi,
can someone quickly explain group 8? what exactly do I see there? is it the injection amount? but why is it listed three times?
Greetings
Post19-03-2004, 19:46    Subject: 003 and 008 Log from ASV inside Quote
http://www.dieselschrauber.de/Solldaten_Main.html
Look at the 3rd. Column...
Hello, Rainer
BlauBaer
Post19-03-2004, 20:11    Subject: 003 and 008 Log from ASV inside Quote
That's all very nice, but what does that actually mean for me?
driver request: what I tell the ECU regarding the accelerator pedal position
Torque Limiting???
Smoke Reduction???
and how much does he actually inject? 1, 2, or 3? or the subtraction from the three?
in the log, Dieselmartin also had to extract the minimum value and perform a subtraction...why was this done?
Greetings
Jan6K
Avatar-Jan6K
Post19-03-2004, 20:19    Subject: 003 and 008 Log from ASV inside Quote
These are the values from the 3 measurement fields, and the minimum value is always injected.
That's exactly the trick of this control system.
Jan
1Z5 CFHF / AHB H4D
BlauBaer
Post20-03-2004, 9:44    Subject: 003 and 008 Log from ASV inside Quote
do you mean the russian minimum, or the one that dieselmartin added as the last column?
because the minimum in idle, '0' would be the desired value '0', so nothing would happen. This would cause it to turn off.
but the terms themselves are still not clear to me.
torque limitation? what is that? or flow limitation? (maybe: flow limitation: is that the maximum amount that can be injected before it clogs? - what happens to the value if 10 cent tuning is applied? or does the STG (presumably a device) not recognize 10 cent tuning at all?)
Greetings
Post20-03-2004, 11:43    Subject: 003 and 008 Log from ASV inside Quote
So
the 3 columns are the
- Driver's request (Even when the gas pedal is released and the vehicle is stationary or idling, the minimum amount is displayed here)
- Gear shift limitation to prevent you from accidentally disengaging the gear.
At least 3 values must be entered.
The subtraction is used to find out when the RUSSGRENZE was at its minimum.
Because this means the engine was "starving," usually due to a faulty mass airflow sensor (MAF).
If this happens only a few (rare) times, it shouldn't be a big deal.
However, if the E-quantities are constantly or in typical conditions (ALWAYS at full throttle) limited by the Russ, something goes wrong.
Monday, I got my accident-damaged bike back!
No new posts Such a Log vim AFN (Gfx inside) On-Board Diagnostics (OBD)
