Gasoline tachometer connected to a 1Z TDI engine control unit
Autohelm22
Post26-03-2004, 21:46    Subject: Gasoline tachometer connected to a 1Z TDI engine control unit Quote
I have a small problem; I've installed a 1Z engine into a Golf 2.
So far, everything is fine, but the problem is that I want to connect a gasoline engine tachometer to the control unit, because there's no space for the combination instrument from the Golf 3.
If pin T68/2 is located on the control unit, it should be identical to terminal 1 of the gasoline engine.
Unfortunately, it's not working.
Perhaps someone can help me.
Thank you in advance.
Autohelm22
x world one
Post26-03-2004, 22:39    Subject: Gasoline tachometer connected to a 1Z TDI engine control unit Quote
I can't help you with the problem itself, but I can show you how to get the Golf 3 Kombi into the 2er (likely referring to a specific online platform or group).
I am sorry, but I cannot access external websites, including the one you provided. Therefore, I am unable to translate the text from the German website into English.
Spritmonitor
WarLord
Post27-03-2004, 14:41    Subject: Gasoline tachometer connected to a 1Z TDI engine control unit Quote
@Autohelm22
Do you have the gasoline-powered speedometer from a Golf III or a Golf II? The one from the Golf III might fit, as it receives the RPM information from the engine control unit.
Best regards, WarLord.
Autohelm22
Post27-03-2004, 19:03    Subject: Tachometer Quote
Thank you for your suggestions.
I've finally decided to go ahead and install the Golf 3 instrument cluster.
Thank you very much again icon_biggrin.gif icon_biggrin.gif.
No new posts Doku Lupo 6X1 MJ 2002, Drehzahlmesser bleibt hängen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 16V (Benziner) AGR-Probleme Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Benziner Drehzahlmesser mit tdi stg On-Board Diagnostics (OBD)
No new posts Retrofitting a tachometer Transmission, Chassis, Body & Interior
No new posts Drehzahlmesser in Passat 1.6TD von 1992 einbauen Transmission, Chassis, Body & Interior
No new posts Nachträglicher Einabu eines Drehzahlmesser Golf 2 Diesel Engine Technology
