AFN: Location of the sensor plug.
konjoy
Post08-04-2004, 12:18    Subject: AFN: Location of the sensor plug. Quote
My engine starts poorly when it's already warm. I know this topic has been discussed many times before. I've already checked and replaced all sorts of things. It could be that the starter injection amount is too low when the engine is warm. The car has had starting problems for a long time. If I disconnect the sensor connector and the engine starts well, can it still be due to the starter motor, or do I just need to have the starter injection amount increased?
My question is now: Where is the probe located?
Translated on 17-08-2026, 5:17.
Post08-04-2004, 18:05    Subject: AFN Sensor Plug Location: Find it here! Quote
konjoy wrote:
My question is now: Where is the feeler gauge located?
If you're referring to the water temperature sensor: This should be a dual-sensor for both the EDC (Electronic Diesel Control) and the combination instrument in all AFN engines, so it would have 4 wires.
The sensor must be located somewhere on the engine, inside one of the coolant hoses or pipes.
For example, in a Volkswagen Golf 3, it's located above the clutch bell and is accessible from the front.
Translated on 17-08-2026, 5:19.
No new posts Do windows open on their own? General Tips
No new posts Doku A3 8P1, Bodenbelag löst sich Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Where is the differential pressure sensor located? Diesel Engine Technology
No new posts Where exactly is the air filter box located for a 2.5 TDI... Diesel Engine Technology
No new posts Injection start cannot be adjusted on the 1Z Upload
No new posts TDI: GRA unlock issue - 90PS engine On-Board Diagnostics (OBD)
