Uneven idle speed on the AXR engine
ckone
Post07-04-2004, 20:37    Subject: Uneven idle speed on the AXR engine Quote
Hello!
'Since today, I'm experiencing a problem with my Polo TDI with an AXR engine: it runs unevenly when idling, and this is being transmitted to the interior as a shaking sensation.'
Otherwise, everything is fine; it runs normally and doesn't misfire while driving.
I've already used VAG-Com to read the error memory, but there's nothing stored in it.
What could that be?
Thank you.
Post08-04-2004, 10:10    Subject: Uneven idle speed on the AXR engine Quote
Have you looked at the idle speed control system?
A friend of mine once replaced two PD elements at a workshop, but they only realized that the dual-mass flywheel was damaged after the fact.
Luckily, the workshop covered the costs.
ckone
Post08-04-2004, 13:41    Subject: Uneven idle speed on the AXR engine Quote
Okay, the idle-sleep regulation values seem normal; all four are moving between -1 and icon_smile_thumb_up.gif.
I just did a 0 to 100 km/h test for fun, and the stated time for my Polo is 10.7 seconds, but it actually takes me over 13 seconds. icon_sad.gif icon_sad.gif
Could it be the LLM?
I've also already tested the LMM values using VAG-Com, and they seem to be normal. The idle speed is around 300 RPM, and the full throttle speed is around 900 RPM.
Post08-04-2004, 16:00    Subject: Uneven idle speed on the AXR engine Quote
If the mass airflow sensor (MAF) consistently reads above 900 when the engine is at full throttle, it doesn't necessarily mean it's broken.
Does he *really* always bring so much? I have only seen the LMM (likely meaning "leakage mass flow") drop below 3000 so far!
"Besides, recently while driving a 110 (ASV), I had a problem with the mass airflow sensor (MAF). There was a leak, which occasionally caused the airflow to drop to 0 mg, making the car feel like it was jumping around like a kangaroo!"
Can you please post a log of your LMM values?
Avatar-Jan6K
Post08-04-2004, 16:35    Subject: Uneven idle speed on the AXR engine Quote
Please perform Ulf's permeability test (-> see the relevant article). That's much more descriptive than just saying "0 to 100," because I doubt you managed to perfectly control the car and drive right on the edge of spinning out, etc.
Jan.
1Z5 CFHF / AHB H4D
ckone
Post08-04-2004, 17:23    Subject: Uneven idle speed on the AXR engine Quote
Okay, I'm going to run a stress test now and create a log file.
I was just on the highway, and it's only going 180 km/h.
Coincidentally, a Polo TDI with 75 horsepower was behind me, and I couldn't shake it off icon_sad.gif.
Something's not right.
ckone
Post09-04-2004, 11:09    Subject: Uneven idle speed on the AXR engine Quote
Okay, I've recorded a log file now.
Someone really needs to check if everything is correct.
http://home.arcor.de/chris_kern/LOG-01-008-010-011.CSV{MARKER}
VipViper2000
Post09-04-2004, 15:04    Subject: Uneven idle speed on the AXR engine Quote
I also had the same problem with my AXR and the stuttering when idling. My workshop has replaced almost everything that could be the cause: all the glow plugs, the engine control unit, and they cleaned the AGR valve...
Occasionally, it still vibrates just a tiny bit when it's standing still. Replacing the engine control unit made the most difference; however, it's a known issue with VW.
VipViper2000
Post09-04-2004, 20:09    Subject: Uneven idle speed on the AXR engine Quote
ckone wrote:
Okay, I've now recorded a log file.
[url][/url]
Honestly, my eyes hurt when I try to decipher that.
If you create a .xls file and copy the .csv data into it using the "Paste Values" function, the overall appearance will be significantly more readable.
And if you then write about what is actually listed in each column (-> technical article about target values
), you would probably also get serious answers icon_wink.gif.
Don't take this personally, but if you're expecting help, it's my opinion that you should make things reasonably easy for the people who are helping you.8)http://home.arcor.de/chris_kern/LOG-01-008-010-011.CSV{MARKER}{MARKER}
ckone
Post10-04-2004, 12:50    Subject: Uneven idle speed on the AXR engine Quote
Okay everyone, problem solved. I replaced the diesel filter today, and it seems it was completely blocked.
The jerking is gone, and it's pulling normally again icon_biggrin.gif icon_biggrin.gif.
Thank you very much, everyone.
Post11-04-2004, 11:36    Subject: Uneven idle speed on the AXR engine Quote
ckone wrote:
So guys, it's all sorted out, I replaced the diesel filter today, and it seems it was completely blocked.
It's already a positive thing that you're telling us the solution icon_smile.gif - but I (or we?) would also be interested in the story of your diesel filter: its age, mileage, and whether it was operated with biodiesel (possibly mixed with conventional diesel)?
ckone
Post11-04-2004, 17:01    Subject: Uneven idle speed on the AXR engine Quote
Hi Ulf!
Okay, the mileage is 56,000 km, and it's been in use for exactly 2 years and 5 months.
I have never filled up with biodiesel icon_smile.gif.
I've always used regular diesel, mostly from Aral.
Post11-04-2004, 18:36    Subject: Uneven idle speed on the AXR engine Quote
ckone wrote:
So, the mileage is 56,000 km, and it has been in use for exactly 2 years and 5 months.
Well, with a recommended service interval of 30,000 km (does that apply to yours?), and therefore almost a 100% "extension" of the replacement interval, it's quite possible that the thing is already clogged.
No new posts Misfires on 2.0 TDI engine, rough running Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku 2,4 & 2,8 l Motoren, unrunder Leerlauf Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What is the synchronization angle in a TDI engine? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. 2.0 TDI - Germany - Engine misfiring, white smoke Diesel Engine Technology
No new posts Peugeot Boxer extrem unrunder Lauf Diesel Engine Technology
No new posts 1.6TDI CAY, uneven running, constantly faulty injector Diesel Engine Technology
No new posts AIFO Iveco 8061 Engine Stalling / Rough Running Diesel Engine Technology
