Audi A2 central locking, no confirmation
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
avoso
Post05-04-2004, 19:39    Subject: Audi A2 central locking, no confirmation Quote
I recently bought an Audi A2. When locking/unlocking using the remote key, there is no confirmation, such as a short beep or the hazard lights flashing.
Is this function not supposed to be available on the A2 model?
Thank you in advance, and best regards.
Okay, here's the translation:
Achim.
mersente
Post05-04-2004, 20:49    Subject: Audi A2 central locking, no confirmation Quote
Hello, you can turn the blinking or honking feature on or off in the comfort control module.
Post06-04-2004, 14:18    Subject: Audi A2 central locking, no confirmation Quote
It's also possible that some of the door contact switches aren't working correctly. So, if a door on my Golf/Passat isn't closed properly, nothing will light up. Since this function is enabled by default (blinking), I suspect there might be a problem with the door electronics. Could there be a control light illuminating in the A2 area, or is there a display showing something?
AND
Does the red LED in the driver's door blink after locking with the remote control?
avoso
Post06-04-2004, 16:31    Subject: Audi A2 central locking, no confirmation Quote
Hello and thank you for your replies!
According to the error memory of the comfort control unit, there is no error present! How can I activate the horn/turn signal function?
Achim.
mersente
Post06-04-2004, 20:55    Subject: Audi A2 central locking, no confirmation Quote
Unfortunately, I can't determine that this week because I'm on vacation. Perhaps someone here knows more, otherwise you'll have to wait until after Easter.
avoso
Post07-04-2004, 16:30    Subject: Audi A2 central locking, no confirmation Quote
Okay, just don't stress out!
Thank you in advance, and have a lovely Easter celebration!
Achim.
Cheffe
Post10-04-2004, 15:05    Subject: Audi A2 central locking, no confirmation Quote
You can check it out yourself if you have a VAG 1551 or something similar.
To do this, go to the comfort control unit (address word 46), then select "adjustment" (10), and then select channel 8 (-> flashes when unlocking) and channel 9 (flashes when locking). Value 1 enables the function, and 0 disables it.
Boss.
avoso
Post12-04-2004, 12:38    Subject: Audi A2 central locking, no confirmation Quote
Hey boss,
Thank you for your reply!
Unfortunately, that didn't help me either. 'I'm only getting the message 'Channel 8 is not available'!'
I've also made changes to the central locking system on other VW/Audi vehicles, but something seems different about the A2!
Does anyone else have any ideas about what might be causing this?
Thank you and best regards.
Achim.
No new posts Audi Central Locking Adjustment Options Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Customization options for Volkswagen central locking systems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Zentralverriegelung öffnet selbsständig Transmission, Chassis, Body & Interior
No new posts AFB-Motor Audi/keine v-max Diesel Engine Technology
No new posts Audi A3 8P BKD Air Conditioning Not Working Transmission, Chassis, Body & Interior
No new posts Audi A3 1.9 TDI 130 PS keine Leistung bis 2800 U/min Diesel Engine Technology
