Loose Air Intake Hose: What are the Effects?
Klausel
Post11-04-2004, 20:20    Subject: Loose Air Intake Hose: What are the Effects? Quote
Hello!
Volkswagen Golf III, AFN engine (110 hp), manufactured in 1997, mileage: 126,000 km.
I saw today that the small hose at the bottom rear of the air filter housing...
It probably came loose during the last visit to the workshop (inspection and technical inspection).
Happened 2 months ago.
The hose is positioned in the opposite direction of travel and ends a few centimeters later in a...
T-piece, and ultimately probably into AGR components, if I understand the technical article about AGR correctly.
Understood.
What does this mean for the engine? Could any damage have occurred?
Could that have been the reason for the problems I've been experiencing lately?
namely, intermittent stuttering (the engine cuts out for approximately 1/3 of a second).
accompanied by a brief flash of the red warning light for brake fluid/parking brake.
or the parking light - this happened both when accelerating at low speeds.
Both the engine speed and the idle speed at a traffic light.
Thank you for the responses.
Klaus.
Translated on 26-07-2026, 14:03.
Marco
Post11-04-2004, 21:46    Subject: Loose Air Intake Hose: What are the Effects? Quote
Hello Klaus,
That hose likely connects to the crankcase ventilation system.
Reattach the hose and you're done. The only thing that could happen if the hose is disconnected is that some oil might leak into the engine compartment.
Translated on 26-07-2026, 14:06.
Post11-04-2004, 22:35    Subject: Loose Air Intake Hose: What are the Effects? Quote
If the hose is thin and connects to a T-fitting, I would tend to think it's part of the vacuum system.
If the hose is loose and rattles, dirt can be drawn into the magnetic valves that control the EGR system and the variable geometry turbocharger (VGT).
You can imagine the consequences: sooner or later, it just won't work anymore...
Translated on 26-07-2026, 14:07.
Klausel
Post11-04-2004, 23:07    Subject: Loose Air Intake Hose: What are the Effects? Quote
Hello!
Thank you for the answers.
(1) Will everything be alright again if the solenoid valves are replaced, or could other components have also been damaged?
(2) Could the problems I'm experiencing be caused by these items that may already be contaminated?
Greetings, Klaus.
Translated on 26-07-2026, 14:08.
Post12-04-2004, 10:28    Subject: Loose Air Intake Hose: What are the Effects? Quote
Klausel wrote:
Hello!
Greetings, Klaus
Your intermittent issues sound more like a problem with relay 109 to me.
Just reattach the hose; hopefully, it hasn't sucked in too much debris, especially if you haven't been driving around construction sites a lot.
Translated on 26-07-2026, 14:10.
Post12-04-2004, 10:31    Subject: Loose Air Intake Hose: What are the Effects? Quote
Hi Clause,
You definitely won't want to just replace those valves without a proper reason; they cost between €80 and €110!
Swallowing something while lights are flashing likely has nothing to do with the valves; it's more related to the infamous relay 109 (search for more information).
When I got my TDI, the hose on the air filter housing was also disconnected. You have to disconnect it in order to change the air filter, and some mechanics don't remember to reconnect the hose afterward icon_evil.gif.
Translated on 26-07-2026, 14:12.
Klausel
Post12-04-2004, 15:45    Subject: Loose Air Intake Hose: What are the Effects? Quote
I also considered the Relais 109, but I thought that models from 1997 already had the improved version.
Relay installed. Well, maybe they'll break too - I'll replace it.
Thank you for the answers!
Greetings, Klaus.
Translated on 26-07-2026, 14:13.
Andy
Post12-04-2004, 16:13    Subject: Loose Air Intake Hose: What are the Effects? Quote
I also thought about relay 109, but I assumed that models from 1997 already had the improved version.
Relay installed.
Of course not... At least, in my Golf from the year 1997, it still has that good old 'Made in Tunisia' label.
It started showing signs of failure 8 weeks ago. It was just a small crack on the circuit board, but it's still something.
Andy.
Translated on 26-07-2026, 14:14.
No new posts Golf 1J documentation up to 05/99, loose license plate light Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Servicedeckel Heckklappe lose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dodge Sharan 7M, Loose Side Bumper Cover Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Hose: Connection & Oil Issues Diesel Engine Technology
No new posts DPF Loose Parts: Buy Now & Save! Diesel Engine Technology
No new posts Injector bridge suddenly loose - how is that possible? Diesel Engine Technology
No new posts Defective PD Elements: Loose Spring & Piston Diesel Engine Technology
